An overview of the Territory Solution toolset
Disponible con licencia de Business Analyst.
The Territory Solution toolset contains tools to set up, modify, and manage territories. This toolset allows you to build territory hierarchy, manage external variables, and set up constraints.
A territory solution is organized in levels. A level represents a hierarchy in the territory solution. It can represent sales regions, service areas, franchise zones, or voting districts. Each territory solution contains a base, or alignment level, that is the foundation of the solution.
Tool |
Description |
Creates a new empty feature class to represent a level. |
Creates a copy of a territory solution. |
Creates feature classes for a specified territory level. |
Creates a new territory solution with two levels and loads input features into the base level. |
Exports a territory solution to a feature class. The export includes records from all levels (hierarchy) of the solution. |
Creates a summary report of a territory solution or a comparison report of two solutions. |
Creates a new territory solution and imports the territories hierarchy from a table or a layer. |
Adds records (features) or updates existing records for the specified level. |
Creates a group layer that represents a territory solution from an existing territory solution dataset. |
Updates the territory solution to reflect changes made to the base level. |
