Import Territory Solution (Territory Design Tools)
Resumen
Creates a new territory solution and imports the territories hierarchy from a table or a layer.
Uso
  • The input data should have a hierarchical structure.
  • Specifying more than a single level will create a hierarchy.
Parámetros
Input Data
The layer or records to be imported.
Table View
Territory Solution Name
The name of the territory solution to be created.
String
Level Settings
The level settings for importing the territories hierarchy.
Columnas de la tabla de valores:
  • Level Name—The name of the level (required).
  • Default Territory Name—The prefix for the new territories that will, subsequently, be created at the level (optional).
  • ID Field—The field that contains IDs (unique IDs) for territories (required).
  • Name Field—The field that contains names for territories (optional).
  • Parent ID Field—The field that contains IDs of parent territories (optional).
  • Primary Feature Class—Specifies the class level that will be used for storing level attributes (optional).
    • Territory Boundaries—Level attributes will be stored using the boundaries of the territory solution.
    • Territory Centers—Level attributes will be stored using the boundary centers of the territory solution.
    • Base Boundaries—Level attributes will be stored using the boundaries of the base layer.
    • Base Centers—Level attributes will be stored using the boundary centers of the base layer.
Value Table
Salida derivada
Output Territory Solution
The updated territory solution.
Group Layer
Entornos
Current Workspace
Información de licenciamiento
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Avanzado: Requires Business Analyst
