Generate Territory Report (Territory Design Tools)
Resumen
Creates a summary report of a territory solution or a comparison report of two solutions.
Uso
  • The Territory Solution should contain at least one level variable.
  • A report can be created for an individual level or all levels.
Parámetros
Input Territory Solution
The input territory solution for the report.
Group Layer; Feature Dataset; String
Level
Specifies the territory level that will be used to create the report.
  • All Levels—All territory levels will appear in the report.
String
Report Type
(Opcional)
Specifies the type of report that will be generated.
  • Territory Summary—The report will contain a summary of a territory solution, such as hierarchy and statistics. This is the default.
  • Compare Territories—The report will compare two territory solutions.
  • Realignment—The report will contain a summary realignment report for the territories.
  • Realignment Detailed—The report will contain a list of the reassigned features.
String
Output Report Folder
(Opcional)
The output location where the report will be saved.
Folder
Report Title
(Opcional)
The title of the report.
String
Report Output Formats
(Opcional)
Specifies the format of the output report.
  • PDF—The report will be in PDF format. This is the default.
  • XLSX—The report will be in XLSX format.
  • HTML—The report will be in HTML format.
  • ZIP—The report will be in ZIP format.
  • CSV—The report will be in CSV format.
String
Comparison Territory Solution
(Opcional)
The territory solution for the comparison report.
Comparison Level
(Opcional)
Specifies the territory level that will be used for the comparison or realignment report.
  • All Levels—All territory levels will be used for the comparison or realignment report.
String
Salida derivada
Output Report
The output report file.
File
Entornos
Current Workspace
Información de licenciamiento
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Avanzado: Requires Business Analyst
