Apply Building Offsets (Topographic Production Tools)
Resumen
Aligns, moves, and hides building features or calculates offset values for bridge features based on product specification rules defined in an .xml file.
If this tool is run with a building offset XML rule file, it aligns, moves, and hides building marker symbols based on product specification rules defined in an .xml file.
If this tool is run with a bridge offset XML rule file, it calculates the offset values necessary to properly display bridges at a given location. These values can be calculated for bridge features with line or point geometry.
Line bridge feature offsets will be calculated for the width of a bridge based on the overpassing feature that runs through the bridge
Point bridge features offsets include the following:
The rotation angle of a bridge based on its overpassing feature
The position of the bridge if the original position is not coincident with the overpassing feature
Nota:
A product file installer is available for ArcGIS Topographic Mapping. The product files contain predefined XML rule files that can be used for cartographic production.
Uso
The feature layers referenced in the rule file must have their symbology defined pursuant to the product specification using ArcGIS Arcade expressions.
The layers must have attribute-driven symbology enabled for marker symbols.
The tool will create an
ABO_Rotationfield in the Buildings table if one does not already exist and connect the rotation property of building marker symbols to this attribute.
Parámetros
| Etiqueta | Explicación | Tipo de datos |
Input Map |
The map that contains the layers with proper symbology. This can be a map in the application or an |
Map |
Rule File |
An |
File |
Salida derivada
Updated Map |
The updated map with modified building features and symbology. |
Map |
Entornos
Esta herramienta no utiliza ningún entorno de geoprocesamiento.
Información de licenciamiento
- Basic: No
- Standard: No
- Avanzado: Requires Topographic Mapping
