Import MGCP Metadata (Topographic Production Tools)
Resumen
Imports Multinational Geospatial Co-production Program (MGCP) or MGCP Urban Vector Data (MUVD) metadata to an MGCP or MUVD database.
Uso
Precaución:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
  • The metadata can only be imported into an MGCP or MUVD database.
  • The input .xml files must match the MGCP or MUVD metadata specification and be compliant with MGCP or MUVD Technical Reference Documents (TRDs).
  • Data is imported into MGCP or MUVD feature classes.
Parámetros
Metadata Files
The .xml files that contain the metadata that will be imported.
File
Cell or ResourceSrf Features
The Cell or ResourceSrf feature class where the metadata will be imported.
Feature Layer
Metadata Type
(Opcional)
Specifies the type of metadata that will be imported.
  • MGCP—Multinational Geospatial Co-production Program metadata will be imported. This is the default.
  • MUVD—MGCP Urban Vector Data metadata will be imported.
String
Salida derivada
Output Cell or ResourceSrf Features
The Cell or ResourceSrf feature class that has been updated with information from the input metadata XML.
Feature Layer
Entornos
Esta herramienta no utiliza ningún entorno de geoprocesamiento.
Información de licenciamiento
  • Basic: No
  • Standard: Requires Topographic Mapping
  • Avanzado: Requires Topographic Mapping
