Split Features (Topographic Production Tools)
Resumen
Splits features on input feature classes for any number of polyline or polygon target feature classes using the cutting features, and inserts points on the cutting feature.
Uso
Precaución:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
  • The Cutting Features parameter value must have at least one feature selected. A warning will be returned if no features are selected.
  • Target features will be divided into multiple features at any point where they intersect the source features.
  • The Cutting Features parameter value will have new vertices added at every point where they intersect the target features.
  • Run the Integrate tool using the Cutting Features and Target Features parameter values to help ensure spatial integrity before using this tool. This is important when complex polygon features are involved.
Parámetros
Cutting Features
The cutting features that will be used to split the target features where they intersect the target feature class geometries.
Feature Layer
Target Features
The features that will be divided by the cutting features.
Feature Layer
Use Target Z Values
Specifies whether the z-value from the source or target will be used.
  • Activado—The z-value from the source or target will be used.
  • Desactivado—The z-value from the source or target will not be used. This is the default.
Boolean
Salida derivada
Output Features
The features that were divided by the Cutting Features value.
Feature Layer
Entornos
Esta herramienta no utiliza ningún entorno de geoprocesamiento.
Información de licenciamiento
  • Basic: No
  • Standard: Requires Topographic Mapping
  • Avanzado: Requires Topographic Mapping
