ListDatabaseSequences
Résumé
The ListDatabaseSequences function lists the database sequences in a database.
This function is only supported for file geodatabases.
Syntaxe
ListDatabaseSequences(workspace)
| Le paramètre | Explication | Type de données |
workspace |
A database that has one or more sequences. |
String |
Valeur de retour
| Type de données | Explication |
Object |
A list of |
Exemple de code
ListDatabaseSequences example
List and describe the database sequences in a file geodatabase.
import arcpy
sequences = arcpy.da.ListDatabaseSequences("C:/Data/myGdb.gdb")
for seq in sequences:
print('Sequence name: {}'.format(seq.name))
print('Sequence start value: {}'.format(seq.startValue))
print('Sequence increment value: {}'.format(seq.incrementValue))
print('Sequence current value: {}'.format(seq.currentValue))
