VehicleRoutingProblemSchemaVersion
Résumé
Enumeration specifying the schema version to use for a VehicleRoutingProblem analysis.
Discussion
An updated VehicleRoutingProblem object schema was introduced in ArcGIS Pro 2.7 to provide enhanced usability and to more closely match the schema of Vehicle Routing Problem layers introduced in ArcGIS Pro 2.6.
Learn more about the Vehicle Routing Problem schema changes
It is recommended that all new VehicleRoutingProblem analyses use schema version Two. Schema version One is maintained for backward compatibility.
Propriétés
Nom Explication Type de données
One
(Lecture seule)
The original VehicleRoutingProblem schema version, which more closely resembles the schema of Vehicle Routing Problem layers in ArcGIS Desktop.
Object
Two
(Lecture seule)
The updated VehicleRoutingProblem schema version, which more closely resembles the schema of Vehicle Routing Problem layers in ArcGIS Pro. It is recommended that all new analyses use this schema version.
Object
