KrigingModelUniversal
Résumé
Defines the Universal Kriging model. The available model types are Linear with linear drift and Linear with quadratic drift.
Discussion
The KrigingModelUniversal object is used in the Kriging tool.
The Universal Kriging types (Linear with linear drift and Linear with quadratic drift) assume that there is a structural component present and that the local trend varies from one location to another.
Universal Kriging assumes the model:
\(Z(s) = µ(s) + ε(s)\)
A default value for lagSize is initially set to the default output cell size.
For majorRange, partialSill, and nugget, a default value will be calculated internally if nothing is specified.
Syntaxe
KrigingModelUniversal({semivariogramType}, {lagSize}, {majorRange}, {partialSill}, {nugget})
Nom Explication Type de données
semivariogramType
(Facultatif)
Semivariogram model to be used.
  • LINEARDRIFT—Universal Kriging with linear drift.
  • QUADRATICDRIFT—Universal Kriging with quadratic drift.
The default value is LINEARDRIFT.
String
lagSize
(Facultatif)
The lag size to be used in model creation. The default is the output raster cell size.
Double
majorRange
(Facultatif)
Represents a distance beyond which there is little or no correlation.
Double
partialSill
(Facultatif)
The difference between the nugget and the sill.
Double
nugget
(Facultatif)
Represents the error and variation at spatial scales too fine to detect. The nugget effect is seen as a discontinuity at the origin.
Double
Propriétés
semivariogramType
(Lecture et écriture)
String
lagSize
Double
majorRange
Double
partialSill
Double
nugget
Double
Exemple de code
KrigingModelUniversal example 1 (Python window)
Demonstrates how to create a KrigingModelUniversal object and use it in the Kriging tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
kModelUniversal = KrigingModelUniversal("LINEARDRIFT", 70000, 250000, 180000, 34000)
outKrigingUni1 = Kriging("ca_ozone_pts.shp", "ELEVATION", kModelUniversal, 2000, RadiusVariable(),"")
outKrigingUni1.save("C:/sapyexamples/output/kuniversal1")
KrigingModelUniversal example 2 (stand-alone script)
Calculates a kriging surface using the KrigingModelUniversal object.
# Name: KrigingModelUniversal_Ex_02.py
# Description: Uses the KrigingModelUniversal object to run the Kriging tool.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inPointFeature = "ca_ozone_pts.shp"
outVarRaster = "C:/sapyexamples/output/uvariance2"
# Create KrigingModelUniversal Object
lagSize = 70000
majorRange = 250000
partialSill = 180000
nugget = 34000
kModelUniversalObj = KrigingModelUniversal("LINEARDRIFT", lagSize, majorRange,
                                           partialSill, nugget)
# Run
outKrigingUni2 = Kriging(inPointFeature, "ELEVATION", kModelUniversalObj, 2000,
                           RadiusFixed(200000, 10), outVarRaster)
# Save the output
outKrigingUni2.save("C:/sapyexamples/output/kuniversal2")
