< (Relational Less Than) operator
Résumé
Returns 1 for cells where the first raster is less than the second raster and 0 if it is not.
Discussion
The relational less-than operation evaluates the first input value in relation to the second input value on a cell-by-cell basis within the Analysis window. In the relational evaluation, if the condition is true (the first input value is less than the second input value), the output is 1; if it is false, the output is 0.
Input1 < Input2, Output = 1
Input1 = Input2, Output = 0
Input1 > Input2, Output = 0
When one or both input values are NoData, the output is NoData.
When using an operator with a raster input, the result will be a raster. However, if all inputs are numbers, the result will be a number.
When there are multiple operators in an expression, the operators are not necessarily run in left-to-right order. The operator with the highest precedence value will be run first. For more information, see the operator precedence table in Work with operators in map algebra. Use parentheses to control the run order.
Boolean (~, &, ^, |) operators have a higher precedence level than Relational (<, <=, >, >=, ==, !=) operators. When Boolean operators are used in the same expression as Relational operators, the Boolean operators will be run first. To change the order the operators are run, use parentheses.
When multiple Relational or Boolean operators are used consecutively in a single expression, the expression may fail to run in some cases. To avoid this, use appropriate parentheses in the expression so that the run order of the operators is explicitly defined. For more information, see Complex statement rules.
Two inputs are necessary for the evaluation to take place.
The order of the input is relevant for this operator.
Output values are always integer.
If both inputs are single-band rasters, or one of the inputs is a constant, the output will be a single-band raster.
If both inputs are multiband rasters, the operator will perform the operation on each band from one input, and the output will be a multiband raster. The number of bands in each multiband input must be the same.
If one of the inputs is a multiband raster and the other input is a constant, the operator will perform the operation using the constant value for each band in the multiband input, and the output will be a multiband raster.
If both inputs are multidimensional rasters with the same number of variables, the operator will perform the operation for all slices with the same dimension value, and the output will be a multidimensional raster. The variables in the inputs must have the same dimensions or a common dimension but no uncommon dimensions.
If both inputs have one variable but different names, set the Match Multidimensional Variable environment to False to perform the operation.
If one of the inputs is a multidimensional raster and the other input is a constant, the operator will perform the operation for all slices for all variables using the constant value, and the output will be a multidimensional raster.
Opérandes
| Opérande | Explication | Type de données |
in_raster_or_constant1 |
The input being tested to determine if it is less than the second input. If one of the inputs is a raster and the other is a scalar, an output raster will be created with the evaluation being performed for each cell in the input raster. |
Raster Layer | Constant |
in_raster_or_constant2 |
The input against which the first input is tested to be less than. If one of the inputs is a raster and the other is a scalar, an output raster will be created with the evaluation being performed for each cell in the input raster. |
Environnements
Cell Size, Current Workspace, Mask, Output Coordinate System, Extent, Scratch Workspace, Snap Raster
Exemple de code
This sample performs a Less Than operation on two input rasters.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
outLessThan = Raster("degs") < Raster("negs")
outLessThan.save("C:/sapyexamples/output/outlt.tif")
# Name: Op_LessThan_Ex_02.py
# Description: Performs a relational less-than operation on two inputs
# on a cell-by-cell basis within the Analysis window
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inRaster1 = Raster("degs")
inRaster2 = Raster("negs")
# Run LessThan
outLessThan = inRaster1 < inRaster2
# Save the output
outLessThan.save("C:/sapyexamples/output/outlt")
