VfBinary
Résumé
Defines the relationship between the vertical cost factor and the vertical relative moving angle through a binary function. If the vertical relative moving angle is greater than the low-cut angle and less than the high-cut angle, the vertical factor is set to the value associated with the zero factor; otherwise it is infinity.
VfBinary vertical factor graph
Graph of the binary vertical factor.
Discussion
This object is used in the Distance Accumulation and Distance Allocation Spatial Analyst tools, as well as the Path Distance, Path Distance Allocation, and Path Distance Back Link Legacy Distance tools.
The vertical factor (VF) object defines the relationship between the vertical cost factor and the vertical relative moving angle (VRMA).
VF defines the vertical difficulty encountered in moving from one cell to the next.
VRMA identifies the slope angle between the FROM or processing cell and the TO cell.
When the VRMA is larger than the low-cut angle and smaller than the high-cut angle, the VF for moving between the two cells is set to the value associated with the zeroFactor. If the VRMA is greater than the highCutAngle or lower than the lowCutAngle, the VF is set to infinity.
Syntaxe
VfBinary({zeroFactor}, {lowCutAngle}, {highCutAngle})
Nom Explication Type de données
zeroFactor
(Facultatif)
The zeroFactor will be used to position the y-intercept of the binary function.
The default value is 1.0.
Double
lowCutAngle
(Facultatif)
The VRMA degree defining the lower threshold, below which (less than) the VFs are set to infinity.
The default value is -30.0.
Double
highCutAngle
(Facultatif)
The VRMA degree defining the upper threshold, beyond which (larger than) the VFs are set to infinity.
The default value is 30.0.
Double
Propriétés
zeroFactor
(Lecture et écriture)
The zeroFactor is used to position the y-intercept for the vertical factor class.
Double
lowCutAngle
Double
highCutAngle
Double
Exemple de code
VfBinary example 1 (Python window)
Demonstrates how to create a VfBinary class and use it in the DistanceAccumulation tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myVerticalFactor = VfBinary(1.0, -30, 30)
outDistAccum = DistanceAccumulation("Source.shp", "", "elev.tif",
                                   "cost.tif", "elev.tif",
                                    myVerticalFactor)
outDistAccum.save("C:/sapyexamples/output/distAccumVfB.tif")
VfBinary example 2 (stand-alone script)
Performs a distance accumulation analysis using the VfBinary class.
# Name: VfBinary_Ex_02.py
# Description: Uses the VfBinary object to run the
#              DistanceAccumulation tool
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inSourceData = "source.shp"
inCostRaster = "costraster.tif"
inElevation = "elev.tif"
# Create the VfBinary Object
zeroFactor = 1.0
lowCutAngle = -30
highCutAngle = 30
myVerticalFactor = VfBinary(zeroFactor, lowCutAngle, highCutAngle)
# Run DistanceAccumulation
outDistAccum = DistanceAccumulation(inSourceData, "", inElevation,
                                    inCostRaster, inElevation,
                                    myVerticalFactor)
# Save the output
outDistAccum.save("C:/sapyexamples/output/distaccumvfB2.tif")
