Work with the MGCP metadata add-in
Disponible avec une licence ArcGIS Topographic Mapping.
The ArcGIS Topographic Mapping extension in ArcGIS Pro includes an add-in that you can use to review Multinational Geospatial Co-production Program (MGCP) and MGCP Urban Vector Data (MUVD) metadata in a comprehensible format. This tool is designed to read and display .xml files used with the Import MGCP Metadata and Export MGCP Metadata tools.
Install the add-in
Complete the following steps to install the add-in:
Ensure that the Topographic Mapping extension is licensed.
Ensure that the product files are installed.
Browse to the
MetadataAddInfolder.The default installation location is
C:\Users\Public\Documents\ArcGIS Topographic Mapping\Product Files\ReferenceData\MetadataAddIn.Double-click
TopographicMetadata.esriAddinXto install the add-in.Click Install Add-In on the Esri ArcGIS Add-In Installation Utility dialog box.
The add-in is installed.
Click OK.
With the add-in installed, you can configure ArcGIS Pro to use the metadata style that fits your needs.
Review metadata in ArcGIS Pro
Once you have installed the metadata add-in, you can use it to review MGCP metadata by completing the following steps:
Start ArcGIS Pro.
Click Settings.
Click Options.
The Options dialog box appears.
In the Application section, click the Metadata tab.
In the Metadata style section, click the Item Description drop-down arrow and choose the style that matches your metadata.
Click OK.
Open a project that contains MGCP metadata in XML format.
Right-click the
.xmlfile and choose View Topographic Metadata.
The metadata appears in a comprehensive format on the Metadata tab.
