Generate Aviation Chart Leads (Aviation Tools)
Résumé
Creates text graphics at intersection points between a map frame boundary and line features.
Chart leads are text elements that are placed where a line feature intersects the edge of the map frame of an aeronautical chart (usually an Enroute chart). Chart leads indicate the next significant point for line features continuing past the map frame by displaying the name of the next designated point or Navigational aid (Navaid) along a particular route. The text to be displayed is based on the line features attributes. To symbolize and place the chart leads, the tool uses preferences. The preferences are configured using a specific interface and should be established before running the tool.
Utilisation
Attention :
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
You can generate chart leads for all the line features in the map frame or selected features. The line features that need to be generated for chart leads are also configured in the preferences.
The preferences from the Preferences Table parameter value will define how the tool generates chart leads.
For the Preference parameter value, specify the chart lead preference.
Paramètres
| Etiqueter | Explication | Type de données |
Layout |
The target layout that contains the map frame for which chart leads will be generated. |
Layout |
Map Frame |
The map frame for which chart leads will be generated. |
String |
Preferences Table |
The table of preferences that controls how the chart leads will be calculated and placed. |
Table View |
Preference |
The list of preferences determined from the Preferences Table parameter. |
String |
Sortie dérivée
Updated Layout |
The updated Layout parameter value with generated chart leads. |
Layout |
Environnements
Cet outil n’utilise pas d’environnement de géotraitement.
Informations de licence
- Basic: No
- Standard: Requires ArcGIS Aviation Charting
- Advanced: Requires ArcGIS Aviation Charting
