Identify Contours (Topographic Production Tools)
Résumé
Identifies types of contours and applies hypsographic codes to input features.
Utilisation
  • This tool processes each input contour and identifies the contour type. It uses the underlying raster and contour features to identify the type of contour. It then updates the contour code field with the appropriate domain code.
  • This tool identifies the following types of contours:
    • Index
    • Intermediate
    • Depression index
    • Depression intermediate
    Attention :
    This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
  • If more than one input raster is used, all input rasters must have the same cell size, band count, and pixel type. All input rasters should also use the same elevation units (meters or feet).
  • If the Number of Depression Contours to Identify parameter value is negative or zero, the tool will not run.
Paramètres
Etiqueter Explication Type de données
Input Contours
The input contours that will be updated with the specified contour codes.
Feature Layer
Input Rasters
The rasters that will be used to derive elevations of points inside contours to correctly identify the types of contours.
Raster Layer; Mosaic Layer
Contour Height Field
The field in the input contour feature class that contains elevation values. This field type must be numeric.
Field
Contour Code Field
The field in the input contour feature class that will be updated with the appropriate domain code.
Field
Contour Index Interval
(Facultatif)
The interval, or distance, between index contour lines. The default is 100.
Long
Index Code
(Facultatif)
The value that will be used to populate the Contour Code Field parameter value when index contours are identified. The default is 1.
String
Intermediate Code
(Facultatif)
The value that will be used to populate the Contour Code Field parameter value when intermediate contours are identified. The default is 2.
String
Depression Code
(Facultatif)
The value that will be used to populate the Contour Code Field parameter value when depression contours are identified. The default is 5.
String
Depression Intermediate Code
(Facultatif)
The value that will be used to populate the Contour Code Field parameter value when depression intermediate contours are identified. The default is 6.
String
(Facultatif)
The number of contours in a depression that will be coded as depressions. The value provided must be greater than zero. If no value is provided, all of the contours in the depression will be coded as depressions.
Long
Area of Interest
(Facultatif)
The layer that defines the processing extent. The layer must have only one selected feature.
Feature Layer
Z Factor
(Facultatif)
The conversion factor that will be used to convert the contour elevation value unit of measurement to match the raster's unit of measurement. The default is 1.
For example, if the elevation values in the input raster are in meters but the contours are in feet, set the z-factor to 3.28084 (1 meter = 3.28084 feet).
Double
Supplemental Contours
(Facultatif)
Specifies the interval at which supplemental contours will be created. Supplemental contours are used when the terrain change is not large enough to be depicted with consistent contour intervals.
  • None—No supplemental contours will be created. This is the default.
  • Half Auxiliary—Supplemental contours will be created at one-half the contour interval.
  • Quarter Auxiliary—Supplemental contours will be created at one-quarter the contour interval.
String
Half Auxiliary Code
(Facultatif)
The code value that will be stored in the Contour Code Field parameter value when a half auxiliary contour is identified. The default code will be 3 if the HQC field exists in the input contour feature class.
String
Quarter Auxiliary Code
(Facultatif)
The code value that will be stored in the Contour Code Field parameter value when a quarter auxiliary contour is identified. The default code will be 14 if the HQC field exists in the input contour feature class.
String
Depression Auxiliary Code
(Facultatif)
The code value that will be stored in the Contour Code Field parameter value when a depression auxiliary contour is identified. The default code will be 22 if the HQC field exists in the input contour feature class.
String
Contour Interval
(Facultatif)
The interval, or distance, between contour lines. This can be any positive number. The default is 20.
Double
Base Contour
(Facultatif)
The value that contours will be generated above and below to cover the entire value range of the input raster. The default is 0.
Double
Sortie dérivée
Updated Contours
The contour feature class where contour codes were updated.
Feature Layer
Environnements
Extent
Informations de licence
  • Basic: No
  • Standard: No
  • Advanced: Requires Topographic Mapping or Aviation Airports or Aviation Charting or Maritime or Bathymetry
