Import MGCP Metadata (Topographic Production Tools)
Résumé
Imports Multinational Geospatial Co-production Program (MGCP) or MGCP Urban Vector Data (MUVD) metadata to an MGCP or MUVD database.
Utilisation
Attention :
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
  • The metadata can only be imported into an MGCP or MUVD database.
  • The input .xml files must match the MGCP or MUVD metadata specification and be compliant with MGCP or MUVD Technical Reference Documents (TRDs).
  • Data is imported into MGCP or MUVD feature classes.
Paramètres
Etiqueter Explication Type de données
Metadata Files
The .xml files that contain the metadata that will be imported.
File
Cell or ResourceSrf Features
The Cell or ResourceSrf feature class where the metadata will be imported.
Feature Layer
Metadata Type
(Facultatif)
Specifies the type of metadata that will be imported.
  • MGCP—Multinational Geospatial Co-production Program metadata will be imported. This is the default.
  • MUVD—MGCP Urban Vector Data metadata will be imported.
String
Sortie dérivée
Output Cell or ResourceSrf Features
The Cell or ResourceSrf feature class that has been updated with information from the input metadata XML.
Feature Layer
Environnements
Cet outil n’utilise pas d’environnement de géotraitement.
Informations de licence
  • Basic: No
  • Standard: Requires Topographic Mapping
  • Advanced: Requires Topographic Mapping
