ListDatabaseSequences
サマリー
The ListDatabaseSequences function lists the database sequences in a database.
This function is only supported for file geodatabases.
構文
ListDatabaseSequences(workspace)
パラメーター 説明 データ タイプ
workspace
A database that has one or more sequences.
String
戻り値
データ タイプ 説明
Object
A list of DatabaseSequence objects. Each object contains properties of the database sequence.
コードのサンプル
ListDatabaseSequences example
List and describe the database sequences in a file geodatabase.
import arcpy
sequences = arcpy.da.ListDatabaseSequences("C:/Data/myGdb.gdb")
for seq in sequences:
    print('Sequence name: {}'.format(seq.name))
    print('Sequence start value: {}'.format(seq.startValue))
    print('Sequence increment value: {}'.format(seq.incrementValue))
    print('Sequence current value: {}'.format(seq.currentValue))
