Report
サマリー
The Report object references a report in an ArcGIS Pro project (.aprx) file. It provides access to common properties and methods.
ディスカッション
An ArcGIS Pro project can contain multiple reports. Reports can be created using the createReport method and are accessed using the listReports method on the ArcGISProject object. The listReports method returns a Python list of Report objects. It is important to uniquely name each report so that a specific report can be easily referenced by its name. Each report has metadata properties that can be viewed or modified. Page information including page units, width, height, and margins can be accessed using the pageInfo property.
The Report object returned using the listReports method also represents the first ReportSection. The referenceDataSource property can be modified using the setReferenceDataSource method. A definitionQuery can be applied to the first report section to filter the rows exported to PDF. The listSections method gives access to all report sections and ReportLayoutSection objects in a report.
Use the exportToPDF method to export the report to a .pdf document.
プロパティ
| 名前 | 説明 | データ タイプ |
definitionQuery (読み取り/書き込み) |
The definition query of the first ReportSection. Use this to filter the records exported to PDF. |
String |
metadata (読み取り/書き込み) |
Get or set the report's Metadata class information. Note that setting metadata is dependent on the |
Metadata |
name (読み取り/書き込み) |
The report's name. It is important that all reports in a project have a unique name so they can be easily referenced by name. |
String |
pageInfo (読み取り専用) |
The report page width, height, units, and margins. The keys for the dictionary are defined as follows:
Dictionary |
referenceDataSource (読み取り専用) |
The reference data source connection information of the first ReportSection. The keys for the dictionary are defined as follows:
Dictionary |
方法
export(export_format, {report_export_options}, {display_options})
The export method exports a Report using a specified export_format and optionally different report_export_options or display_options.
Refer to the ReportExportOptions or the DisplayExportOptions help topics to learn more details and get code samples.
| 名前 | 説明 | データ タイプ |
export_format |
The supported export format object is |
Object |
report_export_options (オプション) |
The |
Object |
display_options (オプション) |
The |
Object |
exportToPDF(out_pdf, {page_range_type}, {page_range}, {starting_page_number}, {total_page_number}, {resolution}, {image_quality}, {compress_vector_graphics}, {image_compression}, {embed_fonts}, {jpeg_compression_quality})
Exports a report to a Portable Document Format (PDF) file.
レガシー:
This method is superseded by export at ArcGIS Pro 3.4 and only remains for use in legacy scripts. All enhancements and future development will only occur on the export method.
PDF files are designed to be consistently viewable and printable across platforms. They are commonly used for distributing documents on the web and are a standard interchange format for content delivery. PDF files are editable in many graphics applications and retain annotation, labeling, and attribute data for map layers. PDF exports support embedding of fonts and can display symbology correctly even if the user does not have Esri fonts installed.
| 名前 | 説明 | データ タイプ |
out_pdf |
A string that represents the path and file name of the output export file. |
String |
page_range_type (オプション) |
A string that defines the type of page range to export. The default is ALL.
The default value is ALL. |
String |
page_range (オプション) |
A string that identifies the pages to be exported if the |
String |
starting_page_number (オプション) |
Applies an offset to the page numbering to add additional pages to the beginning of the report. The default offset is 1. The default value is 1. |
Integer |
total_page_number (オプション) |
The total number of pages to label, for example, when your report displays X of Y pages. This is useful when you want to combine multiple reports into one. The default is -1, which means there is no override. The default value is None. |
Integer |
resolution (オプション) |
An integer that defines the resolution of the export file in dots per inch (dpi). The default value is 96. |
Integer |
image_quality (オプション) |
A string that defines output image quality.
The default value is BEST. |
String |
compress_vector_graphics (オプション) |
A Boolean that controls compression of vector and text portions of the output file. Image compression is defined separately. The default value is True. |
Boolean |
image_compression (オプション) |
A string that defines the compression scheme used to compress image or raster data in the output file.
The default value is ADAPTIVE. |
String |
embed_fonts (オプション) |
A Boolean that controls the embedding of fonts in an export file. Font embedding allows text and character markers to be displayed correctly when the document is viewed on a computer that does not have the necessary fonts installed. The default value is True. |
Boolean |
jpeg_compression_quality (オプション) |
A number that controls compression quality value when The default value is 80. |
Integer |
getDefinition(cim_version)
Gets a report's CIM definition.
CIM-level access to additional object properties was introduced at ArcGIS Pro 2.4. CIM-level access to reports was introduced at ArcGIS Pro 3.1. When you want to return an object's CIM definition, you must specify a cim_version. Esri follows the semantic versioning specification. This means that at major releases—for example, 3.0—breaking API changes are allowed. This allows Python script authors control over which version of the CIM is used during a script run if there is a possibility breaking changes may be introduced in the new version. If you are authoring scripts for ArcGIS Pro 2.x, specify the cim_version to be 'V2'. If you are authoring scripts for ArcGIS Pro 3.x, specify the cim_version to be 'V3'. Scripts authored using cim_version 'V2' will continue to work in ArcGIS Pro 3.x.
For more information about working with the CIM and samples, see Python CIM access.
| 名前 | 説明 | データ タイプ |
cim_version |
A string that represents the major version of the CIM. |
String |
戻り値
| データ タイプ | 説明 |
Object |
Returns the CIM definition for a |
listSections({wildcard})
Returns a Python list of ReportSection and ReportLayoutSection objects in a report.
| 名前 | 説明 | データ タイプ |
wildcard (オプション) |
A wildcard is based on the section name and is not case sensitive. A combination of asterisks (*) and characters can be used to help limit the resulting list. The default value is None. |
String |
戻り値
| データ タイプ | 説明 |
List |
A Python list of ReportSection and ReportLayoutSection objects in a report. |
openView()
Opens and activates a new report view pane in the application.
This is useful if the report view is not already open or another view is active in the application. The method creates a report view zoomed to its full extent and activates it. To close other, existing views before opening a new view, use the ArcGISProject closeViews method.
注意:
This method is designed to be run in the application using a script tool, Notebook, or the Python window. It will have no effect if run outside of the application.
setDefinition(definition_object)
Sets a report's CIM definition.
For more information about working with the CIM and samples, see Python CIM Access.
| 名前 | 説明 | データ タイプ |
definition_object |
A modified CIM definition object originally retrieved using |
Object |
setReferenceDataSource(data_source)
Sets a report's reference data source.
The setReferenceDataSource method sets the data source that the report references using a Layer object, a Table object, or a string that represents the path to an external data source
| 名前 | 説明 | データ タイプ |
data_source |
The data reference that powers the report. This parameter can be a The default value is None. |
Object |
updatePageInfo(pageInfo)
Updates the report page information.
The page width and height values are based on the units specified in the dictionary. If you change the units, you may also want to change the width and height values.
| 名前 | 説明 | データ タイプ |
pageInfo |
Dictionary |
コードのサンプル
The following script exports a report to PDF using a page range:
aprx = arcpy.mp.ArcGISProject(r"C:\DemoData\USA_States.aprx")
report = aprx.listReports("Cities Report")[0] # Find report by name
report.exportToPDF(r"C:\DemoData\CitiesReport.pdf", page_range="2-10")
The following script changes the metadata for a report:
report = aprx.listReports("States Report")[1] # Find second report by name
md = report.metadata # Get report metadata
md.title = "Modified States Report"
md.save()
The following script sets the reference data source for the first report section in a report:
report = aprx.listReports("Counties Report")[0] # Find report by name, this also returns the first report section
report.setReferenceDataSource(r"C:\DemoData\USA_States.gdb\Counties")
print(report.referenceDataSource)
#{'dataset':'counties', 'workspace_factory':'File Geodatabase',
# 'connection_info':{'database':'C:\\DemoData\\USA_States.gdb'}}
The following script modifies the definition query for the first report section in a report:
report = aprx.listReports()[2] # Find the third report in the project
print(report.name)
# State Population Report
report.definitionQuery = "STATE_NAME = 'California'"
print(report.definitionQuery)
# STATE_NAME = 'California'
The following script gets all report and report layout section objects using listSections:
aprx = arcpy.mp.ArcGISProject('current') # Run this from the Python window in Pro
report = aprx.listReports("Complete Report")[0] # Find report by name
sections = report.listSections() # Get all report and report layout sections in a report
for s in sections:
print(f"Section Name: {s.name} Section Type: {s.type}")
# Section Name: Cover Page Section Type: REPORT_LAYOUT_SECTION
# Section Name: Cities Section Type: REPORT_SECTION
# Section Name: States Section Type: REPORT_SECTION
The following script changes the report definition for a text element:
aprx = arcpy.mp.ArcGISProject(r'C:\projects\WaterSupply.aprx')
report = aprx.listReports('Suppliers')[0] # Find the report by name
df = report.getDefinition('V3') # Get the current CIM definition of the report
report_section = df.elements[0] # Find the first report section in the CIM
report_header = report_section.elements[4] # Find the report header subsection
title_text = report_header.elements[3] # Find the title text element
symbol = title_text.graphic.symbol.symbol # Get the text symbol
symbol.fontFamilyName = "Arial" # Change the font
report.setDefinition(df) # Set the new CIM definition
The following script creates a report and opens a new view:
aprx = arcpy.mp.ArcGISProject('current') # This must be run in the application
map = aprx.listMaps('TaxLots')[0] # Find the map by name
# Define report properties
ds = map.listTables('Owners')[0] # Find the data source table by name
pi = {'width': 297, 'height': 420, 'units': 'MILLIMETER', 'margins': 'WIDE'} # Define page info
f = [{'fieldName': 'Name', 'sortInfo': 'DESC', 'groupField': False},
{'fieldName': 'Address', 'sortInfo': 'ASC', 'groupField': False},
{'fieldName': 'Status', 'sortInfo': 'None', 'groupField': False}] # Define fields
s = [] # Pass no statistics
report = aprx.createReport(
page_info = pi,
data_source = ds,
fields = f,
statistics = s,
name = 'Owners') # Create the report
report_view = report.openView() # Open a new report view
The following script gets the page information for a report:
page_info = pi,
data_source = ds,
fields = f,
statistics = s,
