ClosestFacilitySolverProperties
サマリー
Provides access to analysis properties from a closest facility network analysis layer. The GetSolverProperties function is used to obtain a ClosestFacilitySolverProperties object from a closest facility network analysis layer.
ディスカッション
The ClosestFacilitySolverProperties object provides read and write access to all the analysis properties of a closest facility network analysis layer. The object can be used to modify the desired analysis properties of the closest facility layer, and the corresponding layer can be resolved to determine the appropriate results. A new closest facility layer can be created using the Make Closest Facility Analysis Layer geoprocessing tool. Obtaining the ClosestFacilitySolverProperties object from a new closest facility layer allows you to reuse the existing layer for subsequent analyses rather than create a layer for each analysis, which can be slow.
After modifying the properties on the ClosestFacilitySolverProperties object, the corresponding layer can be immediately used with other functions and geoprocessing tools. There is no refresh or update of the layer required to honor the changes modified through the object.
プロパティ
| 名前 | 説明 | データ タイプ |
accumulators (読み取り/書き込み) |
Provides the ability to get or set a list of network cost attributes that are accumulated as part of the analysis. An empty list, |
String |
attributeParameters (読み取り/書き込み) |
Provides the ability to get or set the parameterized attributes to be used in the analysis. The property returns a Python dictionary. The dictionary key is a two-value tuple consisting of the attribute name and the parameter name. The value for each item in the dictionary is the parameter value. Parameterized network attributes are used to model some dynamic aspect of an attribute's value. For example, a tunnel with a height restriction of 12 feet can be modeled using a parameter. In this case, the vehicle's height in feet should be specified as the parameter value. If the vehicle is taller than 12 feet, this restriction will then evaluate to Attempting to modify the Do not attempt to modify the
Modify the
If the network analysis layer does not have parameterized attributes, this property returns |
Dictionary |
defaultCutoff (読み取り/書き込み) |
Provides the ability to get or set the default impedance value at which the solver will stop searching for facilities for a given incident. A value of |
Double |
defaultTargetFacilityCount (読み取り/書き込み) |
Provides the ability to get or set the number of closest facilities to find per incident. |
Integer |
ignoreInvalidLocations (読み取り/書き込み) |
Specifies whether invalid input locations will be ignored. Typically, locations are invalid if they cannot be located on the network. When invalid locations are ignored, the solver will skip them and attempt to perform the analysis using the remaining locations.
String |
impedance (読み取り/書き込み) |
Provides the ability to get or set the network cost attribute used as impedance. This cost attribute is minimized while determining the closest facility and the best route to the closest facility. |
String |
outputPathShape (読み取り/書き込み) |
Provides the ability to get or set the shape type for the route features that are output by the solver. The following is a list of possible values:
String |
restrictions (読み取り/書き込み) |
Provides the ability to get or set a list of restriction attributes that are applied for the analysis. An empty list, |
String |
solverName (読み取り専用) |
Returns the name of the solver being referenced by the Network Analyst layer used to obtain the solver properties object. The property always returns the string value Closest Facility Solver when accessed from a |
String |
streetDirectionsProperties (読み取り/書き込み) |
Provides read and write access to |
Object |
timeOfDay (読み取り/書き込み) |
Provides the ability to get or set the time and date at which the routes should begin or end. The interpretation of this value depends on whether Instead of using a particular date, a day of the week can be specified using the following dates.
For example, to specify that the route should start or end at 8:00 a.m. on Monday, specify the value as The |
DateTime |
timeOfDayUsage (読み取り/書き込み) |
Controls whether the value of the
String |
timeZoneUsage (読み取り/書き込み) |
Specifies the time zone of the
Irrespective of the
String |
travelDirection (読み取り/書き込み) |
Provides the ability to get or set the direction of travel between facilities and incidents during the analysis. The following is a list of possible values:
String |
travelMode (読み取り専用) |
Accesses the travel mode set on a network analysis layer as an |
Object |
useHierarchy (読み取り/書き込み) |
Controls the use of the hierarchy attribute while performing the analysis. The following is a list of possible values:
String |
uTurns (読み取り/書き込み) |
Provides the ability to get or set the policy that indicates how the U-turns at junctions that could occur during network traversal between stops are being managed by the solver. The following is a list of possible values:
String |
方法
applyTravelMode(travel_mode)
Updates the analysis properties of a network analyst layer based on a travel mode object. The updated network analyst layer can then be solved to complete the analysis.
When a network analyst layer is created, it is assigned default values for all of its analysis properties. The individual analysis properties can be updated using a solver properties object obtained from the network analyst layer. A travel mode stores a predefined set of analysis settings that help to perform a particular analysis, such as a walking time travel mode that stores the analysis settings required to perform a time-based walking analysis.
Using the applyTravelMode method, all the analysis settings that are defined in a travel mode can be applied at once. After the analysis properties are updated, the network analyst layer can be solved to complete the analysis.
If there is an error when updating the solver properties, such as when the provided travel mode references properties that don't exist on the current network dataset or references properties that are no longer applicable to the network dataset that was used to create the network analyst layer corresponding to the solver properties object, no exceptions are raised. The method will execute successfully, but you will get errors when you try to solve such a network analyst layer.
If the travel_mode parameter does not reference a travel mode object or a string, a TypeError exception is raised. If the travel_mode parameter references a string and the string cannot be internally converted to a valid string representation of a travel mode object, a ValueError exception is raised.
| 名前 | 説明 | データ タイプ |
travel_mode |
A variable that references a travel mode object derived from a network dataset. A list of travel mode objects can be obtained by calling the |
Object |
コードのサンプル
The script shows how to update the Closest Facility solver properties through a full workflow. This is based on the tutorial network dataset of the San Francisco region.
# Name: ClosestFacilitySolverProperties_Workflow.py
# Description: For some emergency planning a distribution center is seeing how
# long it will take to get to the nearest hospital at different
# times of the day.
# Requirements: Network Analyst extension
# Import system modules
import arcpy
from arcpy import env
import os
import datetime
try:
# Set environment settings
output_dir = r"C:\Data"
# The NA layer's data will be saved to the workspace specified here
env.workspace = os.path.join(output_dir, "Output.gdb")
env.overwriteOutput = True
# Set local variables
input_gdb = "C:/Data/SanFrancisco.gdb"
network = os.path.join(input_gdb, "Transportation", "Streets_ND")
layer_name = "ClosestHospital"
travel_mode = "Driving Time"
direction = "TO_FACILITIES"
cutoffs = 4
in_facilities = os.path.join(input_gdb, "Analysis/Hospitals")
in_incident = os.path.join(input_gdb, "Analysis/DistributionCenter")
nine_in_the_morning = os.path.join(output_dir, "Output.gdb", "nine_in_the_morning")
mid_day = os.path.join(output_dir, "Output.gdb", "mid_day")
# Create a new Closest Facilities layer. The warehouse is concerned with an
# accident during their workday and wants to know how long it will take to
# get to the closest hospital.
result_object = arcpy.na.MakeClosestFacilityAnalysisLayer(network,
layer_name, travel_mode,
direction,
number_of_facilities_to_find = 1,
time_of_day = "1/4/1900 09:00 am")
# Get the layer object form the result object. The closest facility layer
# can now be referenced using the layer object.
layer_object = result_object.getOutput(0)
# Get the names of all the sublayers within the closest facility layer.
sub_layer_names = arcpy.na.GetNAClassNames(layer_object)
# Store the layer names that we will use later
facilities_layer_name = sub_layer_names["Facilities"]
incidents_layer_name = sub_layer_names["Incidents"]
routes_layer_name = sub_layer_names["CFRoutes"]
# Load the hospital locations as facilities.
arcpy.na.AddLocations(layer_object, facilities_layer_name, in_facilities,
# Load the distribution center location as incidents
arcpy.na.AddLocations(layer_object, incidents_layer_name, in_incident,
# Solve the closest facilities layer
arcpy.na.Solve(layer_object)
# Save the resulting route sublayer
arcpy.management.CopyFeatures(routes_layer_name, nine_in_the_morning)
# Get the solver properties object from the closest facility layer
solverProps = arcpy.na.GetSolverProperties(layer_object)
# Update the breaks to 1, 4, and 10 minutes
solverProps.timeOfDay = "1/4/1900 12:00 pm"
# Solve the closest facility layer
arcpy.management.CopyFeatures(routes_layer_name, mid_day)
except Exception as e:
# If an error occurred, print line number and error message
import traceback
import sys
tb = sys.exc_info()[2]
print("An error occurred on line %i" % tb.tb_lineno)
print(str(e))
This script shows how to apply the TruckingTime travel mode to an existing layer.
#Get the closest facility layer object from a layer named "Closest Facility" in
#the map
doc = arcpy.mp.ArcGISProject('current')
map_obj = doc.listMaps()[0]
cf_layer = map_obj.listLayers('Closest Facility')[0]
#Get the Trucking Time travel mode from the network dataset
desc = arcpy.Describe(cf_layer)
travel_modes = arcpy.na.GetTravelModes(desc.network.catalogPath)
trucking_mode = travel_modes["Trucking Time"]
#Apply the travel mode to the analysis layer
solver_properties = arcpy.na.GetSolverProperties(cf_layer)
solver_properties.applyTravelMode(trucking_mode)
