Add Variable Based Suitability Criteria (Business Analyst Tools)
Краткая информация
Adds criteria based on the values calculated for the input layer using the Enrich Layer tool.
Использование
  • You must be signed in to ArcGIS Online or connected to a locally stored dataset.
  • The input analysis layer can be created using the Make Suitability Analysis Layer tool.
  • The selected variables are used to enrich the site layer.
  • Set the influence for each criteria using the Set Criteria Property tool.
Параметры
Подпись Объяснение Тип данных
Input Suitability Analysis Layer
The Suitability Analysis layer that will be used in the analysis.
Feature Layer; Group Layer
Variables
The variables from which the suitability criteria will be determined.
String
Производные выходные данные
Output Suitability Analysis Layer
The name of the Suitability Analysis layer that will be added to the map.
Feature Layer
Output Criteria Name
The name of the criteria that will be added to the Suitability Analysis layer.
String
Параметры среды
Current Workspace, Data Source
Информация о лицензировании
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Advanced: Requires Business Analyst
