Create Target Group (Business Analyst Tools)
Краткая информация
Creates a new target group. A target group is a container for targets that you create, name, and populate with segments from a locally installed Business Analyst dataset.
Использование
  • The output Target Group parameter value will contain one or more targets.
  • The Targets parameter value is a collection of segments.
  • Segment IDs are separated by semicolons when more than one is assigned to a target, for example, 1C; 3A; 9B.
  • A target's color is defined by a hexadecimal value. For example, the hex color code for the RGB value of rgb(66, 135, 245) is #4287f5. If a hex code is not provided, the default color scheme will be applied.
  • The output of this tool is a new target group (*.sgtargetgroup).
Параметры
Подпись Объяснение Тип данных
Output Target Group
The name of the output target group file.
File
Targets
Specifies a list of the targets that will be added to the new target group.
Столбцы таблицы значений:
  • Name–The name of the target.
  • Segments–The segments to be added to the target.
  • Color–The color associated with the segment.
Value Table
Параметры среды
Current Workspace, Data Source, Display Segment Names
Информация о лицензировании
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Advanced: Requires Business Analyst
