Generate Customer Demographic Profile Report (Business Analyst Tools)
Краткая информация
Creates a report summarizing demographic information for polygon features, based on a distribution of points (such as customer points).
Использование
  • The Input Features parameter value must be a point feature class. This is often a customer layer.
  • The Weight Field parameter value must be of numeric type. This parameter allows you to apply differential weighting to individual customers when computing the average demographic profile and produces a weighted average of the geographic unit characteristics—for example, population, households, median age, based on the chosen field, rather than a simple average where each customer contributes equally.
  • By default, the Geography Level parameter uses the lowest level in the Business Analyst dataset.
  • When selecting additional Esri reports from the Additional Reports parameter, variables displayed as raw counts or totals in these other templates are not recommended for this tool. This can lead to incorrect or misleading representations of the data, especially for variables that are not intended to be interpreted as averages, rates, medians, or other derived statistics.
Параметры
Подпись Объяснение Тип данных
Input Features
The point feature class that will be used in the report. This is often a customer layer.
Feature Layer
Output Folder
The output directory that will contain the report.
Folder
Weight Field
(Дополнительный)
A numeric field from the Input Features parameter value to use as a weight when calculating the demographic profile.
Field
Additional Reports
(Дополнительный)
The report template or templates that will be used in addition to the default report template.
String
Report Output Formats
(Дополнительный)
Specifies the format that will be used for the generated report.
  • PDF–The output report will be in PDF format. This is the default.
  • HTML–The output report will be in HTML format.
  • XLSX–The output report will be in XLSX format.
String
Report Title
(Дополнительный)
The title of the report.
String
Subtitle
(Дополнительный)
The subtitle of the report.
String
Add Infographic Header
(Дополнительный)
Specifies whether a header will be added to your infographic report template. The header contains Title and Subtitle information.
  • Отмечено–A header will be added to the infographic report template.
  • Не отмечено–A header will not be added to the infographic report template. This is the default.
Boolean
Add Infographic Footer
(Дополнительный)
Specifies whether a footer will be added to the infographic report template.
  • Отмечено–A footer will be added to the infographic report template.
  • Не отмечено–A footer will not be added to the infographic report template. This is the default.
Boolean
Add Infographic Data Source
(Дополнительный)
Specifies whether a data source will be added to the infographic report template.
  • Отмечено–A data source will be added to the infographic report template.
  • Не отмечено–The infographic report template will not contain a data source. This is the default.
Boolean
Comparison Features
(Дополнительный)
The feature class that will be used as comparison features in the report.
Feature Layer
Comparison Weight Field
(Дополнительный)
A numeric field in the customer layer that will be used in the comparison study.
Field
Geography Level
(Дополнительный)
The geography level that will be used when generating a comparison.
String
Output Feature Class
(Дополнительный)
The output feature class containing summarized customer data.
Feature Class
Производные выходные данные
Output Files
The output report.
File
Параметры среды
Data Source, Display Segment Names
Информация о лицензировании
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Advanced: Requires Business Analyst
