Generate Segmentation Profile Report (Business Analyst Tools)
Краткая информация
Creates a report that displays segments of your customers and compares them to the study area (base profile).
Использование
  • The report displays the count, percent, and index of each segment of customers.
  • The report will calculate the volume information if the Base Profile parameter value contains volume information.
Параметры
Подпись Объяснение Тип данных
Target Profile
A segmentation profile representing the segments that will be profiled. The target profile typically represents your customer segmentation profile.
File
Base Profile
A segmentation profile representing the base profile segments. This is the segmentation that will be used for comparison. The base profile typically represents your market area segmentation profile.
File
Report Title
(Дополнительный)
The title of the report.
String
Output Report Folder
(Дополнительный)
The output location where the report will be saved.
Folder
Report Output Formats
(Дополнительный)
Specifies the format of the output report.
  • PDF—The report will be in PDF format. This is the default.
  • XLSX—The report will be in XLSX format.
  • HTML—The report will be in HTML format.
  • CSV—The report will be in CSV format.
  • PAGX—The report will be in PAGX format.
String
Производные выходные данные
Output Report
The output report file.
File
Параметры среды
Current Workspace, Data Source, Display Segment Names
Информация о лицензировании
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Advanced: Requires Business Analyst
