Set Territory Attribute Constraints (Territory Design Tools)
Краткая информация
Sets variables for adding constraints when solving the territory solution.
Использование
  • Only variables that have been added to the level will be available.
  • Territories are constrained by the Minimum, Maximum, and Ideal Value values.
  • Set the Constraints parameter's Weight option to 100 if there is only one variable that will be used for constraints.
  • The Constraints parameter's Weight option will be set automatically if there are multiple variables.
  • The Constraints parameter's Maximum and Minimum options are hard constraints. Territories will not exceed or be below the specified values.
  • The Constraints parameter's Ideal Value option is a soft constraint. Territories can exceed or be below the specified value.
Параметры
Подпись Объяснение Тип данных
Input Territory Solution
The Territory Design solution layer that will be used in the analysis
Group Layer; Feature Dataset; String
Level
The level to which the constraints will be applied.
String
Constraints
(Дополнительный)
The variables that will be used for constraining the territory solution.
Столбцы таблицы значений:
  • Variable–Numeric value to be used as the constraint.
  • Minimum–Numeric value that sets a hard limit for the territories' lower bound.
  • Maximum–Numeric value that sets a hard limit for the territories' upper bound.
  • Ideal Value–Numeric value that sets a soft limit for the ideal value for the territory solution.
  • Weight–The influence a constraint value has on the territory solution. The number must be greater than 0.
Value Table
Производные выходные данные
Updated Territory Solution
The updated territory solution.
Group Layer
Параметры среды
Current Workspace, Data Source
Информация о лицензировании
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Advanced: Requires Business Analyst
