Generate Excel From Geodatabase (Topographic Production Tools)
Краткая информация
Creates a Microsoft Excel file (.xls or .xlsx) from the contents of a geodatabase.
Использование
  • This tool will create an Excel spreadsheet that defines the schema of a topographic production database and can be used in the Generate Geodatabase From Excel tool.
  • The Excel file that is generated consists of multiple worksheets based on the components of the geodatabase. The individual worksheets in the file contain the spatial reference, datasets, object classes, subtypes, fields, domains, and metadata to be included in the geodatabase.
Параметры
Подпись Объяснение Тип данных
Input Geodatabase
The geodatabase that will be used to create the Excel spreadsheet.
Workspace
Output Excel File
The Excel file that will be created from the geodatabase.
File
Параметры среды
Этот инструмент не использует параметры среды геообработки.
Информация о лицензировании
  • Basic: No
  • Standard: Requires Topographic Mapping
  • Advanced: Requires Topographic Mapping
