Generate Geodatabase From Excel (Topographic Production Tools)
Краткая информация
Creates a geodatabase from the contents of a Microsoft Excel file (.xls or .xlsx).
This tool can only be run with a properly formatted Excel file.
Использование
  • The schema-specific Excel files are included with the ArcGIS Topographic Mapping product data files.
  • The Excel file that is used to generate a geodatabase consists of multiple worksheets based on the components of the geodatabase. The individual worksheets in the file contain the spatial reference, datasets, object classes, subtypes, fields, domains, and metadata to be included in the database.
  • The Excel worksheets have a specific format and items such as the column names cannot be changed. Only the information in the worksheets can be changed.
Параметры
Подпись Объяснение Тип данных
Input Excel File
The Excel file that will be used to generate the geodatabase.
File
Output Geodatabase
The geodatabase that will be generated from the Excel file.
Workspace
Производные выходные данные
Updated Geodatabase
The updated geodatabase.
Workspace
Параметры среды
Этот инструмент не использует параметры среды геообработки.
Информация о лицензировании
  • Basic: No
  • Standard: Requires Topographic Mapping
  • Advanced: Requires Topographic Mapping
