Update GeoNames (Topographic Production Tools)
Краткая информация
Updates the name field on input features based on the information from GeoNames_FeaturesP and GEONAMES_TABLE.
Использование
GeoNames_FeaturesP and GEONAMES_TABLE need to be populated with GeoNames features from the GeoNames to Geodatabase tool.
The GeoName to Feature tool must be run on the features before running this tool.
Внимание:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
Параметры
| Подпись | Объяснение | Тип данных |
Input Features |
The input features that will be updated. Each Input Features value should have field names matching the values specified for the Named Feature ID Field, Name ID Field, and Name Field parameters. |
Feature Layer |
GeoNames Features |
The input GeoNames features that identify unique named feature locations. |
Feature Layer |
GeoNames Table |
A table containing name records related to the input GeoNames features. |
Table View |
Named Feature ID Field |
The field storing GeoNames named feature identifier values. These values should not be null or empty on the input features. |
Field |
Name ID Field |
The field to store GeoNames name identifier values. |
Field |
Name Field |
The field to store GeoNames name values. |
Field |
Производные выходные данные
Updated Features |
Features where |
Feature Layer |
Параметры среды
Этот инструмент не использует параметры среды геообработки.
Информация о лицензировании
- Basic: No
- Standard: Requires Topographic Mapping
- Advanced: Requires Topographic Mapping
