Enrich a layer
需要具有 Business Analyst 许可才能使用。
Enriching a layer appends business and demographic variables to features to further analyze, model, and report on the data. You can enrich polygons using variables from different countries hosted in ArcGIS Online or from a local dataset. These datasets include demographics such as age by race or by sex, population and housing characteristics, labor profiles, business locations, consumer spending, and market potential.
注:
For more information on available data, see Business Analyst data.
Data is available at multiple geographic scales, such as block groups, counties, states, and countries. The Enrich Layer tool uses a proprietary apportionment methodology to more accurately estimate statistics at low levels of geography.
Potential use cases
The following are potential use cases for the Enrich Layer tool:
Application
Examples of data used
Evaluate financial vulnerability
A local government wants to understand the areas in their county with the most socioeconomic vulnerability. They enrich a layer with variables that assess income, housing stability, employment opportunities, and more. Then they use the enriched layer in a suitability analysis, calculating vulnerability scores for each census tract and designing interventions accordingly. To perform this analysis, see the Prioritize intervention with suitability analysis tutorial.
  • Median Household Income
  • Median Disposable Income
  • Per Capita Income
  • HHs: Inc Below Poverty Level
  • For full list, see tutorial linked at left.
Evaluate fire department service areas
A city fire department adds a point feature class representing fire stations in the city and creates drive-time areas around each one. They then enrich the layer with demographic and at-risk variables from the data browser, analyzing whether there are service gaps in high areas of growth and at-risk neighborhoods, furthering a case for new stations to be built more equitably throughout the city.
  • HHs w/1+ Persons w/Disability
  • Owner HHs with 0 Vehicles
Locate potential employees for job recruitment
A regional workforce development agency wants to find out where potential employees are located. Using CBSAs as the level of geography, they enrich a layer with variables that indicate willingness to commute to store locations and other educational attributes. Recruiting efforts can then be narrowed to the key geographies where candidates exist.
  • Workers 16+: Drove Alone
  • Workers 16+: Long-distance/ Commuter Train
  • Commute to Work: x-x Min variables
  • Avg Commute to Work
Create an enriched layer
To enrich a feature layer, complete the following steps:
  1. On the Analysis tab, in the Geoprocessing group, click Tools.
    The Geoprocessing pane appears.
  2. On the Toolboxes tab, in the Business Analyst Tools section, expand the Analysis toolset and click Enrich Layer.
    The Enrich Layer tool opens in the Geoprocessing pane.
  3. Choose the input features you want to enrich by doing one of the following:
    • Use the Input Features drop-down list to choose a layer from the current map.
    • Click the Browse button to choose an existing feature class from other projects or folders.
    • Click the Draw button to draw features on the map.
  4. Use the Output Feature Class parameter to set the name and location of the enriched layer created.
  5. For Variables, click Add to open the data browser and add the variables you want to enrich the layer with.
    From the data browser, you can search and browse for data by category, from custom data, saved variable lists, and from data you have saved as favorites.
  6. For point or line features, do the following:
    1. Use the Define areas to enrich drop-down menu to choose how the areas around the points or lines are defined. Note that travel direction is toward the input points.
      Calculation method
      Definition
      Straight Line
      Creates buffers around point or line features.
      Driving Time or Driving Distance
      Models the movement of cars and other similar small automobiles, such as pickup trucks.
      Trucking Time or Trucking Distance
      Models basic truck travel by preferring designated truck routes.
      Walking Time or Walking Distance
      Follows paths and roads that allow pedestrian traffic.
      Rural Driving Time or Rural Driving Distance
      Models the movement of cars and other similar small automobiles, such as pickup trucks. Follows rules specific to cars. Does not discourage travel on unpaved roads.
    2. Enter the distance or time value for the area around the point or line.
    3. Use the Unit drop-down menu to choose a unit for the distance or time value.
  7. Click Run to finish creating the enriched layer.
    Once the enriched layer is created, it is added to your project and can be used for further analysis and reporting. The enriched layer is a duplicate of the input layer with additional fields containing enriched attributes for each record.
Geoprocessing tool
This page describes the functionality of the Enrich Layer tool. You can also use this geoprocessing tool to build and run queries through a Python script or model. To learn more, see Enrich Layer in the ArcGIS Pro tool reference.
