Use the data browser
需要具有 Business Analyst 许可才能使用。
The data browser is an in-app interface that categorizes and displays all the data variables available in the selected data source. You can access the data browser within the following tools and workflows:
Browse and select variables
Once you have opened the data browser using one of the workflows or tools above, you can browse available variables in the following way:
Click a category.
Variables in the data browser are grouped into categories. Not all categories are available in every country and region.
Click a subcategory.
The variables in the subcategory are listed. To view information about a variable, hover over Info
. You can select a variable group from the Variables list or click the Expand arrow
next to a group to view the variables inside.Optionally, view and filter variables using the hierarchical navigation by doing any of the following:
Click Categories, All Variables, Custom Data, Variable Lists, or Favorites.
Expand and use the Filter options, which vary depending on data source. Filters may include variable year, dataset, and source.
Depending on the workflow you are using, click a variable or check the check box next to a variable to select it. Optionally, click Favorite
to mark any variable as a favorite for quick access through the Favorites list, accessible in the left pane of the data browser.注:
Variables saved as favorites are only listed in the data browser, and are not listed as items in the Catalog pane under My Favorites.
When you are finished choosing variables, click OK.
Search variables
You can search for variables within categories and subcategories or by using keywords. You can do any of the following to search for variables:
Search the entire data browser from the main page, or browse to a category to search within it. In the Search Variables field, type your search terms or a variable ID and press Enter. If enabled, the data browser performs a semantic search, returning variables related to the search terms you entered.
Optionally, search only for variables that match your search terms by clicking Settings
and unchecking the Find related variables check box
注:
For information on enabling semantic search for local and online data, see Semantic search.
Create and save variable lists
Once you have selected variables, you can save the list for future use. Lists you create and save are stored in Variable Lists, accessible in the left pane of the data browser. Variable lists are also displayed as items in the Business Analyst folder in the Catalog pane or view. Variable lists are saved in the current project as a .variablelist file.
注:
The variable lists in the data browser only use variables from the currently selected Business Analyst data source. The variable lists available depend on which data source is selected.
To save a variable list, do the following:
Select variables in the data browser.
Click Selected Variables
to view the list of variables you selected.On the Selected Variables list, do any of the following:
Click Save List to name and store the list for future use.
Click Remove All to empty the list.
Hover over a variable in the list to mark it as Favorite
or view Info
.Reorder the list by dragging and dropping variables, or clicking Move up
and Move down
. You can move a single variable or select and move multiple variables by pressing Ctrl + Shift while clicking.注:
Reordering variables in the Selected Variables list allows you to set the order of fields in resulting attribute tables. For example, variables in the Selected Variables list are ordered top-to-bottom; these variables will display in the same order, left-to-right, in the attribute table.
In the Save Variable List window, type a name for the variable list and click OK.
To edit a saved variable list, right-click it in the Catalog pane or view and select Edit.
Alternatively, some workflows and tools allow you to save the list of variables you have selected in the workflow pane. Below the selected variables, click Save List.
Add a variable list to a project
The Catalog pane displays all your ArcGIS Pro content, including Business Analyst variable lists. To add a previously created variable list to a specific project, do the following:
In the Business Analyst folder in the Catalog pane, right-click a variable list in the Variable Lists folder.
Click Add To My Favorites.
At the top of the Catalog pane, click the Favorites tab, then click My Favorites
.Right-click the variable list, and click Add To Project.
Add a variable list to new projects
You can automatically add a Business Analyst variable list you created to all new projects you create in ArcGIS Pro.
Click Add To New Projects.
The variable list is added to project favorites and to all new projects.
Use custom and shared data
You can access custom data and data shared with you in the left pane of the data browser:
If you are connected to a local or custom data source, click Custom Data to browse, search for, and select variables within custom data.
If you are connected to an online data source, click Custom Data or Shared Content to browse, search for, and select variables within custom data.
Variable calculations
A variable can be used as a count, percentage, average, index value, or reliability estimate. The data browser displays the available calculation options as buttons next to each variable.
注:
To access reliability estimates, margins of error, and confidence scores in the data browser, you must turn on the Show 'margin of error' toggles button when you set the Business Analyst data source.
Count
If you select Count, the analysis uses the estimated count of the variable in the areas defined on the map.
Percentage
If you select Percentage, the analysis uses the variable as a percentage value rather than a count. The percentage is expressed as a ratio to a base value, such as total households or total population, and multiplied by 100. For example, the percentage value for the variable Households with an Internet Subscription is the number of households with an internet subscription, divided by the total number of households in the area (this is the base value). You can view the percent base variable by hovering over the Info icon
Average
This option is available for variables in the Consumer Spending database. If you select Average, the analysis uses the average amount spent per household annually.
Index
If you select Index, the analysis uses an index value indicating how the amount of the variable in the areas defined on the map compares to another value, such as the nationwide average.
There are three types of indices:
Index of value—The variable value for the area divided by the variable value for the entire country, multiplied by 100. For example, the index for Average Household Size is calculated by dividing the Average Household Size value for the specific area by the Average Household Size for the country.
Index of percent value—The variable percentage for the area divided by the variable percentage for the entire country, multiplied by 100. For example, the index of Households that Own 2+ Dogs is calculated by dividing the percentage of Households that Own 2+ Dogs in the specific area by the percentage of Households that Own 2+ Dogs at the country level.
Index of average value—The variable average for the area divided by the variable average for the entire country, multiplied by 100. For example, the index of Health Care Spending is calculated by dividing the average household Health Care Spending in the specific area by the average household Health Care Spending at the country level.
You can view the index type for a variable by hovering over the Info icon
Reliability
This option is available only for American Community Survey variables. If you select Reliability, the analysis uses the Esri reliability score, which is based on the American Community Survey margin of error (MOE) information for the data in the areas defined on the map. The reliability score indicates Esri's confidence in the estimate, based on the MOE provided. Reliability scores are as follows: high reliability, medium reliability, and low reliability.
