Create a color-coded layer
需要具有 Business Analyst 许可才能使用。
The color-coded layer workflow creates a group layer that visualizes the distribution of selected variables on the map. The group layer contains sublayers depicting different geography levels—for example, in the United States, you can view data in state, county, ZIP code, census tract, and block group sublayers. Use the group layer Symbology pane to work with the color-coded group layer.
Potential use cases
The following are potential use cases for the color-coded layer workflow:
Application |
Description |
Examples of data used |
Site a new fulfillment center |
A company wants to identify the best location to open a new fulfillment center. The optimal location requires a high number of workers in the production industry, to ensure the desired skills are present for the fulfillment center positions. They use a color-coded layer to identify areas with the highest percentages of these workers and high spending in the community, and see what incentives are available at the state, county, and local levels. |
Research social determinants of health |
A health researcher is studying social determinants of health. She creates color-coded layers for different factors, such as access to health care and education, to understand how geographic scale affects the distribution of data. |
Advertise to state park patrons |
A state's park and wildlife department is looking to increase use of the state's parks. They create color-coded layers to identify areas of potential park patrons to advertise to, based on demographic and spending indicators. They use the layers to examine interest in park activities at varying geographic levels in the state. |
Create a color-coded layer with local or online data
You can use the color-coded layer workflow in the Business Analysis gallery to select one or two variables and map them at multiple geographic levels as a group layer. To create a color-coded layer, do the following:
On the Analysis tab, click Business Analysis to open the gallery, and click the Color Coded Layer button
.The Data Browser window appears, allowing you to select a variable.
Use the data browser to select a variable and click OK.
注:
You can create a color-coded layer using custom data variables. However, only the custom feature layer is mapped and multiple sublayers are not created.
The project now contains the color-coded group layer, presented in the following ways:
The variable is added to the map and displayed at the highest geography level.
The Contents pane contains a group layer as well as sublayers for each geography level. To view different geography levels on the map, you can zoom in or out, or select a different sublayer in the group layer Symbology pane.
The selected variable is added to the group layer Symbology pane, under Variable.
Optionally, click Add
to open the data browser and add a second variable to the map.注:
Two-variable mapping is not supported with custom data variables or text-based variables, such as Dominant Tapestry Name.
Optionally, modify variables by doing any of the following in the group layer's Symbology pane:
Change the variable calculation by selecting another option. Variable calculation options (such as count, percentage, and index) are displayed beneath the variable name.
Click Options
and select a different variable by clicking Replace variable. If there are two variables on the map, you can click Remove variable to remove one of them.If there are two variables on the map, you can click Switch variables
to switch their order.注:
Switching the variable order impacts the visualization. For Bivariate Colors symbology, the order of variables controls which color is displayed high to low for each variable. For Graduated Symbols symbology, the order of variables controls which variable is styled with symbols and which is styled with color.
Optionally, modify the map style for the group layer (and all sublayers) by clicking the group layer and doing any of the following in the group layer's Symbology pane:
For maps containing one variable, you can change the number of classes into which the data is divided on the map.
For maps containing two variables, you can change the grid size and orientation.
Change the color scheme of the data on the map.
Change the classification method used to group the data.
For more information about symbology for color-coded group layers, see Style options. For information about modifying the symbology for individual sublayers, see Apply symbology to feature layers.
Optionally, set the geography for the analysis using the following options:
Use the Area of interest search field to define the analysis extent using standard geographies. When you enter a search term, a list of standard geographies is displayed in order of population. Click one or more standard geographies in the list to add them to the area of interest. You can remove areas of interest individually or click Clear all.
Use the Boundary Layer drop-down list
to select a polygon layer from the Contents pane as the area of interest. You can use one polygon layer at a time.For Boundary mode, select Geographies or Hexagons. Switching the boundary mode replaces all existing sublayers in the color-coded group layer.
注:
Hexagons are available as a geography option for all local datasets, as well as select online datasets. For information on availability, see Hexagons reference.
Use the Geography group drop-down list to select from different types of geography levels.
Use the Level of detail drop-down list to specify the level of geography to display on the map, such as counties, ZIP codes, or a hexagon resolution.
For more information about setting the geography for a color-coded group layer, see Geography options.
Optionally, click the group layer in the Contents pane and use the Color Coded Group Layer ribbon to do any of the following:
To specify the map extents at which the layer is visible, in the Visibility Range group, click Scale Range and set a maximum and minimum scale. You can click the button again to turn off the setting. For more information, see Display layers at certain scales.
To emphasize different aspects of the map, in the Effects group, use the Transparency, Layer Blend, and Feature Blend options. For more information, see Apply transparency and blending modes.
In the Compare group, use the Swipe and Flicker buttons to compare overlapping layers. For more information, see Change the appearance of a feature layer.
In the Drawing group, access the group layer's Symbology pane or change the classification method.
In the Geography group, change the level of detail.
In the Results group, click View Results
to open the Results pane.
Explore the results
The color-coded layer results are displayed in the Results pane. To open the pane, click View Results
in the Symbology pane or the Color Coded Group Layer ribbon. To learn more about the calculation methods available in the pane, visit Results pane reference.
Summary view
Click Summary
to view a summary of the results. Depending on the type of variables you mapped, the summary includes the count of features, along with the average and median values for the mapped variables. Additionally, it includes other descriptive statistics for the data, as well as the top and bottom five features. If you select features on the map or in the table, the Statistics card updates to provide descriptive statistics for both the selected features and the entire dataset.
Histogram view
Click Histogram
to view the results in a histogram. To explore the histogram, do any of the following:
Select locations on the map by selecting items in the histogram. Click Select interaction mode
to choose which shape to use for selecting (rectangle, polygon, or hand-drawn shape).Click the Results Settings button
. To modify the histogram settings, do any of the following:For maps containing two variables, choose the variable to display in the histogram using the Variable drop-down list.
Modify the method for selecting subsets within the histogram using the options on the Subset Selection Method menu:
Percentage
Set lines at a specified upper and lower percent value. For example, this option can be set to the upper and lower 10 percent, which is the same as the 10th and 90th percentiles.
Standard deviation
Set lines at a specified standard deviation. For example, this option can be set to 1 standard deviation above and below the mean.
Outliers
Set lines to the values that represent 1.5 times the interquartile range (IQR). For example, if the Q3 value is 10 and the Q1 value is 4, the IQR is 6. The lines will be set at 9 below Q1 and 9 above Q3. Any values outside of these lines may indicate that the values are outliers.
In the Bins section, use the Color and Count menus to define the color and number of data groupings in the histogram.
Select subsets of features on the map by using the following options:
Select Lower Subset
—Features in the lower subset are selected.Select Upper Subset
—Features in the upper subset are selected.Select Outer Subsets
—Features in both the lower and upper subsets are selected.Select Middle Subset
—Features in between the lower and upper subsets are selected.
Scatterplot view
Click Scatterplot
to view the results in a scatterplot. To explore the scatterplot, do any of the following:
Select locations on the map by selecting items in the scatterplot. Click Select interaction mode
to choose which shape to use for selecting (rectangle, polygon, or hand-drawn shape).Click Zoom Mode
and zoom in or out of the scatterplot. Click Reset Navigation
to return to the default scatterplot view.Click the Results Settings button
and do any of the following:Use the X-axis, Y-axis, and Dot size drop-down lists to choose the variables used in the chart.
Click the Show regression line toggle button to turn the regression line on or off.
Table view
Click Table
to view the results in a table. To explore the table, do any of the following:
Interact with items in the table and on the map by doing any of the following:
Click an item in the table and the corresponding area is selected on the map. Press Ctrl while clicking to select multiple items.
Right-click a selection to view the contextual menu. Choose Flash to highlight the selection briefly on the map, choose Pan To to move the map to the selection, or choose Zoom To to move the map to the selection and zoom in on it.
Click Clear Selection to deselect items in the table.
View the variable value for each feature, as well as the feature's rank for the selected variable within the area of interest.
Click Transpose Table
to switch the table's rows and columns.Click Export to Excel
to export the data from the color-coded layer to an Excel worksheet.
Style options
You can change the way the data is represented in a color-coded layer by using symbology options to modify the number of classes, the color scheme, and the classification method. The Style section of the group layer's Symbology pane contains these options. Style modifications are immediately reflected on the map.
Symbology
You can visualize your data through a variety of map styles. When you style a color-coded map, the type of data and number of variables determine the styling options. You can experiment with color ramps, line weights, transparency, symbols, and other graphic elements, and see your choices reflected immediately on the map. The map styles are described below.
Graduated colors
Graduated colors symbology can highlight data variances. For example, a light-to-dark color theme can show low-to-high data values. This style maps only one variable, and is the default symbology for maps containing one variable. For more information on this symbology, see Graduated colors.
Bivariate colors
Bivariate colors symbology shows the quantitative relationship between two variables and can be used to emphasize the highest and lowest values on the map or to find correlations. It is the default symbology for maps containing two variables. This symbology applies a distinct graduated color ramp to the classified data in each attribute and combines the color ramps, allowing you to see where the attributes may be related. For more information on this symbology, see Bivariate colors.
Graduated symbols
Graduated symbols symbology allows you to map one or two variables and style the color and size of point symbols on the map. When there is one variable on the map, the color of the symbols remains the same. When there are two variables on the map, the size of the symbols is determined by the first variable; the color of the symbols is determined by the second variable. For more information on this symbology, see Graduated symbols.
Classes
You can change the number of classes, or color-coded groups, into which the data is divided. In the Style section, the Classes drop-down menu allows you to select a number from 1 to 32.
Color schemes
By default, color-coded layers are created using the Yellow-Orange-Red (Continuous) color scheme or the Bivariate Color Scheme grid. You can select another color scheme on the Color scheme drop-down menu. To reverse the color order or create a custom color scheme, click Format color scheme For grids, you can change the values using the Orientation drop-down menu.
Classification methods
Classification methods are used for classifying numerical fields for graduated symbology. The color-coded layer workflow chooses a classification method automatically, based on the variable you selected. You can change the classification method using the Method drop-down menu and selecting from the following options:
Standard Deviation—Automatically selected for a variable calculated as an average, percentage, index, or ratio
Natural Breaks (Jenks)—Automatically selected for a variable calculated as a count or density
Equal Interval—Automatically selected for a variable calculated as a median, rate, or per capita rate
The color-coded layer workflow automatically formats and labels variable information for legibility in each sublayer. For example, it adds the appropriate decimals, commas, and currency or percentage symbols as needed.
Geography options
The color-coded layer workflow allows you to modify the geography settings for the analysis using the Geography section of the group layer's Symbology pane.
Area of interest
The Area of interest search field allows you to specify the exact location or locations to analyze. You can search for any standard geography—such as a state, county, or ZIP code—that is included in the country dataset. The search results display in descending order based on the population total in each listed boundary. When the area of interest is defined, all standard geographies that intersect this boundary are included in the color-coded layer as sublayers.
You can add multiple standard geographies of the same type in the Area of interest field. For example, you could add five counties or ten ZIP codes—but not a county and a ZIP code. Areas of interest can be adjacent (such as Michigan, Ohio, and Indiana) or nonadjacent (such as Kentucky, Florida, and California). If the analysis contains multiple areas of interest, the statistics, ranges, and map settings reflect the whole area. For example, if New York and California are added as areas of interest, the statistics represent one combined area.
注:
If you are using a boundary layer as the area of interest, the features intersecting that boundary layer are mapped. However, if the number of features exceeds 10, the extent of the boundary layer will be mapped instead.
Level of detail
The Level of detail drop-down list displays standard geography levels available for the analysis. The list includes all geography levels with fewer than 10,000 features intersecting the area of interest. Levels with more than 10,000 features intersecting the area of interest are excluded. You can set the level of detail in the following ways:
Select Automatic to dynamically change geography levels based on a balance of scale, visibility, and drawing performance.
Select an individual level to set a fixed geographic level (for example, only show counties).
Levels of detail available in the drop-down list are determined by the geography group selected in the Geography group drop-down list. Geography levels in the U.S. online dataset, for example, are organized in groups by relative topic, such as groups containing levels for administrative or marketing purposes.
Troubleshooting
Use the sections below to troubleshoot potential issues when creating color-coded layers.
Area of interest does not have a valid data source
If you used the Boundary Layer option
to define the area of interest and removed the boundary layer from the Contents pane or its source location, the color-coded layer fails. A warning message appears on the Symbology pane.
Solution
To resolve the area of interest data source, do one of the following:
Click Repair automatically in the warning message to remove the area of interest and reset the color-coded layer to the default standard geography (usually a country boundary).
Repair the layer manually by adding the layer back to the Contents pane, or ensuring it exists in the source location.
Color-coded layer does not have a valid data source
Color-coded layers may fail in the following situations:
If you set a standard geography as the area of interest for a color-coded group layer and close the project without saving, the color-coded layer fails upon reopening the project.
If you select a variable and close the project without saving, the color-coded layer fails upon reopening the project.
In these situations, a warning message appears in the Symbology pane and red warning icons appear on the sublayers in the Contents pane.
Solution
To resolve the color-coded layer data source, click Repair automatically in the warning message. The layer restores the last saved project setting and reconnects all sublayers.
Geoprocessing tool
The Color Coded Layer workflow uses the Color Coded Layer tool. You can use this geoprocessing tool directly to perform the same analysis and build and run queries through a Python script or a model.
