Add Variable Based Suitability Criteria (Business Analyst Tools)
汇总
Adds criteria based on the values calculated for the input layer using the Enrich Layer tool.
用法
You must be signed in to ArcGIS Online or connected to a locally stored dataset.
The input analysis layer can be created using the Make Suitability Analysis Layer tool.
The selected variables are used to enrich the site layer.
Set the influence for each criteria using the Set Criteria Property tool.
参数
| 标注 | 说明 | 数据类型 |
Input Suitability Analysis Layer |
The Suitability Analysis layer that will be used in the analysis. |
Feature Layer; Group Layer |
Variables |
The variables from which the suitability criteria will be determined. |
String |
派生输出
| 标注 | 说明 | 数据类型 |
Output Suitability Analysis Layer |
The name of the Suitability Analysis layer that will be added to the map. |
Feature Layer |
Output Criteria Name |
The name of the criteria that will be added to the Suitability Analysis layer. |
String |
环境
Current Workspace, Data Source
许可信息
- 基本: Requires Business Analyst
- 标准: Requires Business Analyst
- 高级: Requires Business Analyst
