Generate Points From Business Listings (Business Analyst Tools)
汇总
Generates a point feature layer from a business point location search.
用法
  • The Output Feature Class parameter value will exclude the Address field.
  • The following countries contain data required for a Business Listing search: United States and Canada.
  • The Maximum Number of Points to Return parameter has a 5,000 record limit when using online data hosted by ArcGIS Online. For data that is hosted on-premises, the limit is set by the host's administrator.
  • To enable the Business Dataset parameter options, set the Data Source environment to ONLINE.
  • Use a wildcard (*) with a search term or filter value to refine or increase search results. The following are examples:
    • Search Terms parameter—Auto* or *Pizza
    • Filters parameter
      • FilterName—NAICS
      • FilterValue—*71119
    • Filters parameter
      • FilterName—SIC
      • FilterValue—5411*
  • Using the Include Only Exact Matches parameter with the Search Terms parameter will return restrictive results. For example, providing Johnson`s Supermarket for the Search Terms parameter with the Include Only Exact Matches parameter checked, the following will not be returned:
    • Johnson`s Market
    • Johnson`s Supermarket & Pharmacy
    • Johnson and Sons Supermarket & Pharmacy
  • The FilterValue column of the Filters parameter can be set by applying a minimum or maximum value only or by applying a range between the minimum and maximum values as follows:
    • min:number—Filter businesses with variable values less than the number assigned, for example, min:100.
    • max:number—Filter businesses with variable values greater than the number assigned, for example, max:500.
    • min:number max:number—Filter businesses outside of the range of values assigned, for example, min:100 max:500.
    注:
    The above examples are case sensitive. Entering Min:100 in the FilterValue column will be ignored because of the uppercase letter.
    The proper syntax is min:100.
  • The Style parameter includes a Place option, which uses thematic symbols to represent types of businesses and other points of interest. The symbols are assigned to individual points of interest based on a classification code, such as NAICS. The symbols and their classification codes are specific to the Business Analystdataset in use.
参数
标注 说明 数据类型
The output feature class that will contain the returned businesses.
Feature Class
Input Search Features
(可选)
The area that will be used to search for businesses. Selected features supersede the feature class and will be used as the search area.
Feature Layer
Search Terms
(可选)
The terms that will be used to search for businesses. You can use terms such as business name or business type keywords. If this parameter is not set, all businesses from the Input Search Features parameter value will be returned.
String
(可选)
Specifies whether only the text provided for the Search Terms parameter will be returned from the search.
  • 选中—Only exact matches to the text provided for the search_terms parameter will be returned.
  • 未选中—Partial matches to the text provided for the search_terms parameter as well as exact matches will be returned. This is the default.
Boolean
Match Business or Facility Name Only
(可选)
Specifies whether the search will be limited to the business name only.
  • 选中—Only exact matches to the business name provided for the Search Terms parameter will be returned.
  • 未选中—Partial matches to the business name provided for the Search Terms parameter as well as exact matches will be returned. This is the default.
Boolean
Filters
(可选)
The filters that will be applied to the Search Terms parameter.
值表列:
  • FilterName—Set filter by the dataset field.
  • FilterValue—Set filter by applying a value to the selected field.
  • Include—Set filter by including or excluding field values.
    • Include—Field values will be included.
    • Exclude—Field values will be excluded.
Value Table
(可选)
The limit for the number of returned features. The default value is 1,000,000 for local data and 5,000 for online data hosted by ArcGIS Online.
The record limit when using on-premises hosted data is set by your administrator.
Long
Business Dataset
(可选)
The dataset that will be used in the business search.
String
Find related POI
Specifies whether semantic search will be used to find related items to the search terms.
  • 选中—Semantic search will be used.
  • 未选中—Semantic search will not be used. This is the default.
Boolean
Style
(可选)
Specifies the point symbology that will be used for the output feature class.
  • Location—The data will be displayed using a single symbol. This is the default.
  • Place—The data will be displayed using thematic symbols.
String
环境
Current Workspace, Data Source, Extent
许可信息
  • 基本: Requires Business Analyst
  • 标准: Requires Business Analyst
  • 高级: Requires Business Analyst
