Generate Target Group Layer (Business Analyst Tools)
汇总
Generates a layer that identifies geographies that contain selected segments and categorized groups based on targets.
用法
  • If the Boundary Layer parameter is not specified, the Extent environment will be used.
  • Targets are a subclassification of a Target Group parameter value, for example, Core and Development targets. A target can contain one or more segments.
参数
标注 说明 数据类型
Geography Level
The geography level that will be used to define the target layer.
String
Segmentation Base
The segmentation base for the profile being created. The available options are provided by the segmentation dataset in use.
String
Output Feature Class
The output feature class for the target layer.
Feature Class
Target Group
A user-created group of targets. This is used if the dataset supports target groups.
File
Boundary Layer
(可选)
The boundary that will determine the layer extent.
Feature Layer
环境
Current Workspace, Data Source, Display Segment Names, Extent
许可信息
  • 基本: Requires Business Analyst
  • 标准: Requires Business Analyst
  • 高级: Requires Business Analyst
