NbrAnnulus
Zusammenfassung
Defines an annulus neighborhood which is created by specifying an inner and outer circles' radii in either map units or number of cells.
NbrAnnulus neighborhood neighborhood for FocalStatistics function
NbrAnnulus neighborhood example for the FocalStatistics function (inner radius 1 cell, outer radius 3 cells).
NbrAnnulus neighborhood for BlockStatistics function
NbrAnnulus neighborhood example for the BlockStatistics function (inner radius = 1 cell, outer radius = 3 cells).
Diskussion
Tools that use neighborhood annulus object: Block Statistics, Focal Statistics, Point Statistics, Point Density, and Topographic Position Index.
Lizenz:
This class is also available if you have an Image Analyst extension license, but only for the Focal Statistics tool.
The annulus shape is comprised of two circles, one inside the other to make a donut shape. Cells with centers that fall outside the radius of the smaller circle but inside the radius of the larger circle will be included in processing the neighborhood; therefore, the area that falls between the two circles constitutes the annulus neighborhood.
When the annulus object is used and the innerRadius or the outerRadius are not specified, then default values are provided.
The innerRadius must be less than or equal to the outerRadius.
The radius is identified in cells or map units, measured perpendicular to the x- or y-axis. When the radii is specified in map units, they are converted to radii in cell units. The resulting radii in cell units produces an area that most closely represents the area calculated by using the original radii in map units. Any cell center encompassed by the annulus will be included in the processing of the neighborhood.
Syntax
NbrAnnulus({innerRadius}, {outerRadius}, {units})
Name Erläuterung Datentyp
innerRadius
(Optional)
The inner radius of an annulus neighborhood.
The default value is 1.
Double
outerRadius
(Optional)
The outer radius of an annulus neighborhood.
The default value is 3.
Double
units
(Optional)
Defines the units of the neighborhood.
  • CELL—The unit of measurement is in cells.
  • MAP—The units are in map coordinates.
The default value is CELL.
String
Eigenschaften
innerRadius
(Lesen und schreiben)
The inner radius of the annulus neighborhood.
Double
outerRadius
The outer radius of the annulus neighborhood.
Double
units
  • CELL—The units are the number of cells.
String
Codebeispiel
NbrAnnulus example 1 (Python window)
Demonstrates how to create a NbrAnnulus class and use it in the BlockStatistics tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
outNbrA = BlockStatistics("block", NbrAnnulus(1, 2, "CELL"))
outNbrA.save("C:/sapyexamples/output/blstatnbra2")
NbrAnnulus example 2 (stand-alone script)
Implements the BlockStatistics tool using the NbrAnnulus class.
# Name: NbrAnnulus_Ex_02.py
# Description: Uses the NbrAnnulus object to run BlockStatistics tool.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inRaster = "block"
# Create the Neighborhood Object
innerRadius = 1
outerRadius = 3
myNbrAnnulus = NbrAnnulus(innerRadius, outerRadius, "MAP")
# Run BlockStatistics
outBlkStats =  BlockStatistics(inRaster, myNbrAnnulus, "MINIMUM", "DATA")
# Save the output
outBlkStats.save("C:/sapyexamples/output/blstat_Ann3")
