NbrCircle
Zusammenfassung
Defines a circle neighborhood which is created by specifying the radius in either map units or number of cells.
Diskussion
Tools that use neighborhood circle object: Block Statistics, Focal Statistics, Point Statistics, Point Density, Top Hat Transform, and Topographic Position Index.
Lizenz:
This class is also available if you have an Image Analyst extension license, but only for the Focal Statistics tool.
A circle neighborhood is created by specifying a radius value. The radius is identified in cell or map units, measured perpendicular to the x- or y-axis. When the radius is specified in map units, it is converted to a radius in cell units. The resulting radius in cell units produces an area that most closely represents the area calculated by using the original radius in map units. Any cell center encompassed by the circle will be included in the processing of the neighborhood.
Syntax
NbrCircle({radius}, {units})
| Name | Erläuterung | Datentyp |
radius (Optional) |
The radius of the circle neighborhood. The default value is 3. |
Double |
units (Optional) |
Defines the units of the neighborhood.
The default value is CELL. |
String |
Eigenschaften
radius (Lesen und schreiben) |
The radius of the circle neighborhood. |
Double |
units (Lesen und schreiben) |
String |
Codebeispiel
Demonstrates how to create a NbrCircle class and use it in the BlockStatistics tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
outNbrC = BlockStatistics("block", NbrCircle(2, "MAP"))
outNbrC.save("C:/sapyexamples/output/blstatsnbrc2")
Implements the BlockStatistics tool using the NbrCircle class.
# Name: NbrCircle_Ex_02.py
# Description: Uses the NbrCircle object to run BlockStatistics tool.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inRaster = "block"
# Create the Neighborhood Object
radius = 2
myNbrCirc = NbrCircle(radius, "MAP")
# Run BlockStatistics
outBlkStat = BlockStatistics(inRaster, myNbrCirc, "MINIMUM", "DATA")
# Save the output
outBlkStat.save("C:/sapyexamples/output/blstat_cir3")
