Upgrade a highly available ArcGIS Enterprise deployment on AWS
This information applies to upgrading an ArcGIS Enterprise deployment configured on more than one Amazon Elastic Compute Cloud (EC2) instance.
How you upgrade depends on how and when you created the ArcGIS Enterprise deployment on Amazon Web Services (AWS).
To determine what method to use to upgrade, see ArcGIS upgrades on Amazon Web Services ArcGIS upgrades on Amazon Web Services.
Before you upgrade
Regardless of the upgrade method you use, review the following information before you upgrade the deployment:
Read ArcGIS upgrades on Amazon Web Services to determine what method to use to upgrade and discover whether you must perform extra tasks before upgrading to 12.1. Complete all required tasks before upgrading.
Obtain the required ArcGIS licenses for the current software version. Download the license files from your account in My Esri.
Create a backup of the deployment so you can restore if there are any problems with the upgrade procedure.
You can use the
webgisdrutility provided with Portal for ArcGIS to create a backup of most components in an ArcGIS Enterprise deployment.Note:
Depending on what version you are upgrading from, some data store types may not be included in this backup. If you are upgrading a deployment that includes data store types not included when you run the
webgisdrutility, use the ArcGIS Data Storebackupdatastoreutility to create backups of those data store types before you upgrade.
Upgrade using manual upgrade procedures
Using manual procedures to upgrade your multimachine ArcGIS Enterprise deployment on Amazon Web Services is similar to updating software on-premises. You can download software updates from My Esri onto your Amazon Elastic Compute Cloud (EC2) instances, and apply the updates directly to your existing deployment. All ArcGIS Enterprise components on each machine must be running the same software version.
If the starting version or components in your deployment require you to upgrade to an interim version, follow the instructions provided in the interim help version before following instructions to upgrade to 12.1.
Prepare to update components
Complete the following steps to prepare to update components:
Download new versions of Portal for ArcGIS, ArcGIS Web Adaptor, ArcGIS Server, and ArcGIS Data Store and licenses from My Esri.
Ensure that all required ports are open or available.
Consult the port lists for each component and the port diagram.
Ensure that no one is connected to your ArcGIS Enterprise or ArcGIS Server sites.
Caution:
Do not stop the Portal for ArcGIS, ArcGIS Server, or ArcGIS Data Store services. If you stop those services, the
webgisdrutility will fail to create a backup of the deployment.Create a full backup of the deployment using the
webgisdrutility installed with Portal for ArcGIS.You can use the backup file to redeploy the previous software versions if any issues arise during the upgrade process.
Depending on what version you are upgrading, the
webgisdrutility may not include all ArcGIS Data Store types. If your deployment includes a data store type that is not included with the backup created by thewebgisdrutility, use the ArcGIS Data Storebackupdatastoreutility to create a backup of that data store type.
Upgrade Portal for ArcGIS
First, upgrade Portal for ArcGIS.
Make a remote desktop connection (Microsoft Windows) or SSH (Linux) connection to your Portal for ArcGIS machine on AWS. If your portal is highly available, connect to one of the Portal for ArcGIS machines on AWS. Connect as the arcgis user.
If this is the first time you are upgrading Portal for ArcGIS on Windows on AWS, change the arcgis user's password. You must do this for every machine in the deployment, and the password must be the same for all machines.
If you deployed ArcGIS Enterprise using the AWS Management Console, be sure this machine is allowed to create Amazon Simple Storage Service (S3) buckets in your AWS account, as the Portal for ArcGIS upgrade procedure creates an S3 bucket for temporary storage of the content directory. If you deployed using a CloudFormation template provided by Esri, the template already configured this.
Ensure that the required ports are available.
Place the new Portal for ArcGIS and ArcGIS Web Adaptor installations and (if applicable) your new Portal for ArcGIS license file on this machine.
If your deployment contains only one Portal for ArcGIS machine, follow the steps to upgrade Portal for ArcGIS to update the portal machine and its web adaptor, and, if necessary, authorize Portal for ArcGIS with your new license file.
If your portal is highly available, repeat steps 1 and 2 for the second Portal for ArcGIS machine. Next, follow the steps to upgrade a highly available portal to update software and, if necessary, authorize Portal for ArcGIS on each machine with your new license file.
Upgrade ArcGIS Server
Upgrade your hosting server and any additional federated ArcGIS Server sites.
Provide an ArcGIS GIS Server license when upgrading the hosting server. Which license you provide when upgrading federated servers depends on the role the ArcGIS Server fills in your deployment.
You must upgrade ArcGIS Server sites before upgrading ArcGIS Data Store.
Make a remote desktop connection (Windows) or SSH (Linux) connection as the arcgis user to the ArcGIS Server SITEHOST machine for your hosting server.
Place the new ArcGIS Server and ArcGIS Web Adaptor installations and your ArcGIS GIS Server license file on this machine.
If your ArcGIS Server site contains only one machine, follow the instructions in Upgrade ArcGIS Server to upgrade a single-machine site.
If your ArcGIS Server site contains multiple machines, repeat steps 1 and 2 on each machine. Next, follow the instructions in Upgrade ArcGIS Server to upgrade a multiple-machine site.
If you manually federated additional ArcGIS Server sites, connect to those machines and upgrade the software and licenses for those sites as well.
Upgrade ArcGIS Data Store
If you have more than one type of data store configured with your hosting server, upgrade each of them.
Make a remote desktop connection (Windows) or SSH (Linux) connection as the arcgis user to each machine where ArcGIS Data Store is installed.
Place the ArcGIS Data Store installation file on each machine.
Follow the steps to Upgrade ArcGIS Data Store on Windows.
Follow the instructions appropriate to the operating system of the EC2 instances.
Test the upgraded deployment
Test the upgraded ArcGIS Enterprise deployment to ensure all services are running and accessible and your normal workflows still work.
Once testing is successfully completed, you can delete the backup you created before upgrading, as it cannot be used to restore to your upgraded machines.
Tip:
Create a full backup of the successfully upgraded deployment using the webgisdr utility so that you have a base backup of this version of your deployment.
Upgrade using Cloud Builder
If you used ArcGIS Enterprise Cloud Builder for Amazon Web Services to create the deployment and the deployment meets version and functionality requirements described in ArcGIS upgrades on Amazon Web Services, you can use Cloud Builder to upgrade. See Upgrade using the ArcGIS Enterprise Cloud Builder for AWS app for instructions.
Upgrade using Chef scripts
If you created the ArcGIS Enterprise deployment using the highly available ArcGIS Enterprise 10.8 or 10.8.1 Esri Amazon Web Services CloudFormation template (arcgis-enterprise-ha.template.json), you can upgrade using Chef scripts.
As indicated in ArcGIS upgrades on Amazon Web Services, if the deployment is still at version 10.8, 10.8.1, 10.9, or 10.9.1 or if the deployment includes components that are no longer supported, you must first upgrade to an interim version before upgrading to 12.1. Follow the instructions provided in the interim help version before following instructions to upgrade to 12.1.
Upgrade steps are different for deployments on Microsoft Windows and Ubuntu. Follow the instructions applicable to the operating system of your deployment.
Upgrade a highly available ArcGIS Enterprise deployment on Windows
Follow these steps to use Chef to upgrade ArcGIS Enterprise on two EC2 instances (primary and standby).
Upgrade the standby instance
Upgrade the components on the standby instance first.
Make a remote desktop connection to the standby EC2 instance.
Download and install a supported Cinc or Chef client.
See the ArcGIS Cookbook compatibility matrix for supported versions.
Download the 12.1 installation files from your account in My Esri and upload the files to a folder on the EC2 instance:
ArcGIS_Web_Adaptor_for_Microsoft_IIS_121_200166.exePortal_for_ArcGIS_Windows_121_200161.exePortal_for_ArcGIS_Windows_121_200161.exe.001Portal_for_ArcGIS_Web_Styles_Windows_121_200163.exeArcGIS_Server_Windows_121_200157.exeArcGIS_Server_Windows_121_200157.exe.001ArcGIS_DataStore_Windows_121_200164.exeArcGIS_DataStore_Windows_121_200164.exe001
Obtain the Portal for ArcGIS 12.1 authorization file (
.json) and ArcGIS Server authorization licensed for ArcGIS GIS Server (.epcor.prvc) and place them on the EC2 instance.Download the ArcGIS Cookbook version 5.4.0 (
arcgis-5.4.0-cookbooks.zip) to the EC2 instance, unzip the file, and place the contents of the unzipped file in theC:\cheffolder.Delete the following folders:
C:\chef\nodesC:\Users\Administrator\.chef\local-mode-cache
Create a copy of the
C:\chef\node.jsonfile and rename it toupgrade_base_enterprise_ha_windows_standby_step1.json.Open the
upgrade_base_enterprise_ha_windows_standby_step1.jsonfile in a text editor and modify the following parameters:Set the arcgis version to 12.1.
"arcgis" : { "version": "12.1",Set the arcgis archive repository to the folder where you placed the software files on the EC2 instance.
"arcgis" : { "repository": { "archives": "<drive>\\<folder>"Set the server authorization to the location of your ArcGIS Server 12.1 authorization file.
"server" : { "authorization_file" : "<drive>:\\<folder_path>\\My_New_Server.prvc"Set the portal authorization to the location of your Portal for ArcGIS 12.1 authorization file.
"portal" : { "authorization_file" : "<drive>:\\<folder_path>\\my_new_portal.json",Modify the run list to use the following recipes:
"recipe[arcgis-enterprise::install_portal]", "recipe[arcgis-enterprise::webstyles]", "recipe[arcgis-enterprise::install_portal_wa]", "recipe[arcgis-enterprise::server]", "recipe[arcgis-enterprise::server_wa]", "recipe[arcgis-enterprise::install_datastore]"
Save and close the
upgrade_base_enterprise_ha_windows_standby_step1.jsonfile.Open a command line window as an administrator, change the directory to
C:\chef, and run the following command:chef-client -z -j c:\chef\upgrade_base_enterprise_ha_windows_standby_step1.json.
The script runs to upgrade the components on the standby instance.
When the standby upgrade completes successfully, you can proceed to upgrading the primary instance.
Upgrade the primary instance
Once the standby Chef-Run completes, upgrade the primary instance.
Make a remote desktop connection to the primary EC2 instance.
C:\chef\node.jsonfile and rename it toupgrade_base_enterprise_ha_windows_primary_step2.json.Open the
upgrade_base_enterprise_ha_windows_primary_step2.jsonfile in a text editor and modify the following parameters:Set the arcgis version to 12.1.
"recipe[arcgis-enterprise::install_portal]", "recipe[arcgis-enterprise::webstyles]", "recipe[arcgis-enterprise::portal]", "recipe[arcgis-enterprise::portal_wa]", "recipe[arcgis-enterprise::server]", "recipe[arcgis-enterprise::server_wa]", "recipe[arcgis-enterprise::datastore]"
Save and close the
upgrade_base_enterprise_ha_windows_primary_step2.jsonfile.Open a command line window as an administrator, change the directory to
C:\chef, and run the following command:chef-client -z -j c:\chef\upgrade_base_enterprise_ha_windows_primary_step2.json
The script runs to upgrade the components on the primary instance.
When the primary upgrade completes successfully, you can proceed to configure the web adaptor on the standby instance.
Upgrade the web adaptor on standby
Once the primary Chef-Run completes, sign in to the standby instance again to upgrade the web adaptor for the portal.
Make a remote desktop connection to and sign in to the standby EC2 instance.
Make a copy of the
upgrade_base_enterprise_ha_windows_standby_step1.jsonfile and rename it toupgrade_base_enterprise_ha_windows_standby_step3.json.Open
upgrade_base_enterprise_ha_windows_standby_step3.jsonin a text editor and alter the run list to only run the portal_wa recipe."run_list" : [ "recipe[arcgis-enterprise::portal_wa]" ]Open a command line window as an administrator, change the directory to
C:\chef, and run the following command:chef-client -z -j c:\chef\upgrade_base_enterprise_ha_windows_standby_step3.json.
The script configures the ArcGIS Web Adaptor for the portal.
Upgrade a highly available ArcGIS Enterprise deployment on Ubuntu
Upgrade the components on the standby EC2 instance first.
Make an SSH connection to the standby EC2 instance as the ubuntu user.
Use one of the following commands to download and install a supported Chef or Cinc client.
See the ArcGIS Cookbook compatibility matrix for supported versions. Replace the version number text in the following statements with the client version you install.
Chef client:
sudo curl -L https://omnitruck.chef.io/install.sh | sudo bash -s -- -v <version_number>Cinc client:
sudo curl -L https://omnitruck.cinc.sh/install.sh | sudo bash -s -- -v <version_number>
ArcGIS_Web_Adaptor_Java_Linux_121_200209.tar.gzPortal_for_ArcGIS_Linux_121_200206.tar.gzArcGIS_Server_Linux_121_200205.tar.gzArcGIS_DataStore_Linux_121_200208.tar.gzPortal_for_ArcGIS_Web_Styles_Linux_121_200207.tar.gz
arcgis-5.4.0-cookbooks.tar.gz) to the EC2 instance, untar and unzip the file, and place the files contents in the/var/chefdirectory.Delete the
/var/chef/nodesdirectory.Create a copy of the
/etc/chef/node.jsonfile and rename it toupgrade_base_enterprise_ha_ubuntu_standby_step1.json.Open the
upgrade_base_enterprise_ha_ubuntu_standby_step1.jsonfile in a text editor and modify the following parameters:Set the arcgis version to 12.1.
"arcgis" : { "repository": { "archives": "/<path and folder>"Set the server authorization to the location of your ArcGIS Server 12.1 authorization file.
"server" : { "authorization_file" : "/<path>/my_new_server.prvc"Set the portal authorization to the location of your Portal for ArcGIS 12.1 authorization file.
"portal" : { "authorization_file" : "/<path>/my_new_portal.json",Modify the run list to use the following recipes:
"recipe[arcgis-enterprise::install_portal]", "recipe[arcgis-enterprise::start_portal]", "recipe[arcgis-enterprise::webstyles]", "recipe[arcgis-enterprise::install_portal_wa]", "recipe[arcgis-enterprise::unregister_server_wa]", "recipe[arcgis-enterprise::server]", "recipe[arcgis-enterprise::server_wa]", "recipe[arcgis-enterprise::install_datastore]", "recipe[arcgis-enterprise::start_datastore]"
Save and close the
upgrade_base_enterprise_ha_ubuntu_standby_step1.jsonfile.As the ubuntu user, change the directory to
/var/chef, and run the following command:sudo chef-client -z -j /etc/chef/upgrade_base_enterprise_ha_ubuntu_standby_step1.json
Make an SSH connection to the primary EC2 instance as the ubuntu user.
Chef client:
/etc/chef/node.jsonfile and rename it toupgrade_base_enterprise_ha_ubuntu_primary_step2.json.Open the
upgrade_base_enterprise_ha_ubuntu_primary_step2.jsonfile in a text editor and modify the following parameters:Set the arcgis version to 12.1.
Save and close the
upgrade_base_enterprise_ha_ubuntu_primary_step2.jsonfile.As the ubuntu user, change the directory to
/var/chef, and run the following command:sudo chef-client -z -j /etc/chef/upgrade_base_enterprise_ha_ubuntu_primary_step2.json
Once the primary Chef-Run completes, sign in to the standby instance again to configure the web adaptor for the portal.
Make a copy of the
/etc/chef/upgrade_base_enterprise_ha_ubuntu_standby_step1.jsonfile and rename it toupgrade_base_enterprise_ha_ubuntu_standby_step3.json.Open
upgrade_base_enterprise_ha_ubuntu_standby_step3.jsonin a text editor and alter the run list to only run the portal_wa recipe."run_list" : [ "recipe[arcgis-enterprise::portal_wa]" ]As the ubuntu user, change the directory to
/var/chef, and run the following command:sudo chef-client -z -j /etc/chef/upgrade_base_enterprise_ha_ubuntu_standby_step3.json
Upgrade using a CloudFormation template
If you used the 10.9 or later arcgis-enterprise-ha.template.json CloudFormation template to create a highly available ArcGIS Enterprise deployment, you can use the 12.1 arcgis-enterprise-ha-upgrade.template.json file to upgrade t. See Upgrade highly available ArcGIS Enterprise components using CloudFormation for instructions.
If you used 10.9 or later CloudFormation templates to create distributed highly available ArcGIS Enterprise components configured on separate EC2 instances, use the corresponding template to upgrade to 12.1.
The following table lists equivalent deployment and upgrade templates and provides links to instructions for using the upgrade templates:
Deployment template |
Upgrade template |
CloudFormation upgrade template instructions |
Upgrade a highly available Portal for ArcGIS deployment using CloudFormation |
Upgrade a multiple-machine ArcGIS Server site using CloudFormation |
Upgrade a primary-standby ArcGIS Data Store deployment using CloudFormation |
Upgrade a clustered ArcGIS Data Store deployment using CloudFormation |
