Best practices for organization maintenance
As an administrator, you're responsible for configuring ArcGIS Enterprise to meet your organization’s needs and structure during setup and as your requirements change, and to take advantage of new capabilities. It's equally important to regularly maintain members, items, and groups to keep your organization uncluttered and optimally useful for its members. Some of these maintenance tasks, including monitoring use, can help you get the most value from ArcGIS Enterprise.
Tip:
Search partner solutions in ArcGIS Marketplace for apps to help with maintenance tasks, if needed.
Member strategies
The members of your organization are likely to change over time. Strategies for the following common member maintenance tasks are described below:
Add members
You can add members and configure user settings individually or in a batch by uploading a .csv file.
When adding members, do the following:
Before adding members, configure new member defaults to specify member properties such as user type, member role, groups, and member categories to assign to new members.
If your organization has set up categories for organizing members according to characteristics—such as department, location, and expertise—you can specify default member categories to assign to all new members. Member categories make it easier to find and manage members in the organization.
During the invitation process, assign a role with privileges that provide the member access to relevant capabilities. For example, if the member needs to create content, ensure that they have create capabilities.
Remove members
When members leave your organization, you'll need to remove their account and decide what to do with any add-on app licenses, content, or groups that they own. When you delete the member account, the member's licenses, items, and groups are transferred to another member that you specify.
Transition to organization-specific logins
If your organization decides to use organization-specific logins (SAML logins or OpenID Connect logins) after initially setting up built-in accounts, you must migrate members' items and groups from their original account to their new organization-specific account.
Item strategies
The items in your organization will change over time. An item's information, status, and currency may need to be updated over its life cycle. Methods for the following common item maintenance tasks are described below:
Identify old or unused items
Old and unused items consume storage space and can clutter search results. It’s recommended that you periodically review items. Unused and unneeded items can be deleted from the organization. Out-of-date items that are still relevant can be designated as deprecated.
To find the oldest, least frequently modified, or least viewed items in your content, groups, and organization, sort or filter items on the respective tab of the Content page. You can also create an item report showing all items in the organization and sort the report by Date Modified.
Update service URLs in a web map
Web service URLs that are included in live web maps can change over time. During server migrations, the server name may change. Servers will be migrated to HTTPS as it becomes a web standard. You can update the URL referenced by web map layers using the Update References utility on the Settings tab of the map's item page.
You can avoid having to update service URLs in web maps using canonical names, or CNAMEs, for your GIS server machines. CNAMEs are server name aliases that are added to your DNS by your IT department (such as myGISserver.m.com for 50.12.234.12). When a server is migrated to new hardware, you can update the CNAME reference to point to the new server; all service URLs will remain the same, so web map and other service references do not need to be updated.
Update URLs for service or app items
URLs for services hosted in ArcGIS Server and locally hosted web apps may change when servers are retired or renamed. You can update a URL reference to layer and web app items by updating the URL in the Data Source utility on the Settings tab of the item page.
Migrate items between accounts
Many users will never need to use more than one ArcGIS account. However, as an administrator, there are situations in which you may need to copy maps or other items from one account to another.
You can use Change Owner to transfer existing items from one account to another or adjust group ownership. The items remain in the same organization, which means all references and links between layers, maps, and apps are preserved, and everything continues to work as expected. Group membership can also be adjusted.
To transfer items and groups while deleting an account, choose a member from your organization to delete then select the Transfer content and groups option.
Tip:
When migrating accounts with a large number of folders or groups, you can also use ArcGIS API for Python to expedite and maintain the folder structure in My Content. Download the sample script.
Group strategies
Curate featured content using groups and promote a set of groups as the organization’s Featured Groups. (Assign this task to other staff if possible.) If your organization decides to use basemaps other than the default Esri basemaps, create and maintain a group for the basemap gallery.
Identify stagnant groups or groups that are no longer in use, especially public and organizational groups.
Click Groups > My Organization's Groups to view your organization's groups, and reverse the sort order to list oldest groups first.
For each group, view its Content tab to determine the most recently modified items.
Monitor and report activity
It's also important to monitor metrics of your organization’s users and content. Some strategies to monitor and control your organization’s activities are described below.
System usage
Administrators may find it useful to monitor some of the following basic statistics:
Number of members, groups, and items (total and new)
Most active users and most viewed items
Users and groups with the most items
See activity-based metrics in the Dashboard section of the organization's Status page. Download detailed system usage information from the Reports section. Item reports illustrate how users are creating, using, and sharing geographic content. Member reports reveal how users are contributing to the organization.
