Introduction to the ArcGIS Server Administrator Directory
The ArcGIS Server Administrator Directory is a web application primarily designed to help you write administrative scripts for ArcGIS Server. You can browse the Administrator Directory to learn how to construct administrative web service requests through REST. You can then formulate these requests and send them over HTTPS using a scripting language of your choice.
The Administrator Directory is typically available at https://gisserver.example.com:6443/arcgis/admin.
When you attempt to access the ArcGIS Server Administrator Directory on a site that is federated with ArcGIS Enterprise, you must either provide the primary site administrator name and password or use OAuth credentials to sign in as a member of the organization.
Learn more about scripting ArcGIS Server administration
You can also use the Administrator Directory to perform certain administrative functions not available in ArcGIS Server Manager. For example, to create a new geometry service or search service, you must use the Administrator Directory.
