Use available WMS service properties
This topic explains the properties available when using a system-generated capabilities file for WMS services.
Access WMS service properties in ArcGIS Server Manager
To populate or modify the properties of a WMS service in ArcGIS Server Manager, complete the following steps:
Open ArcGIS Server Manager and log in. If you need help with this step, see Log in to Manager.
Click Services > Manage Services.
In the Manage Services module, locate your service, and click Edit
.If your service is not in the list, it may be in a subfolder under the Site (root) folder.
In the Edit module, click Capabilities.
In the capabilities list, click WMS, and verify that WMS is enabled.
In the WMS Configuration list, choose Enter service properties below.
Populate or modify the WMS service properties.
Click Save and Restart.
The edits to your service are applied immediately.
The following table lists the properties available for WMS services and a description of each:
Property |
Description |
Name |
The OGC service type. This property is automatically populated by ArcGIS Server and should not be modified. |
Title |
The name of the map or image service that was used to create the WMS service. This property is automatically populated by ArcGIS Server and should not be modified. |
Abstract |
A narrative description that provides additional information about the WMS service. For example:
Keywords |
A list of keywords or keyword phrases describing the WMS service that aid in catalog searching. For example:
Online Resource |
The OnlineResource property lists the URL of the WMS service. It is necessary for a WMS client to communicate correctly with your WMS service. This property is automatically populated by ArcGIS Server and should not be modified. |
ContactPerson |
The primary contact person for the WMS service. For example:
ContactPosition |
The position of the contact person for the WMS service. For example:
ContactOrganization |
The organization that created the WMS service. For example:
Address type |
The address type used by the organization that created the WMS service. For example:
Address |
The address of the organization that created the WMS service. For example:
City |
The city in which the organization that created the WMS service resides. For example:
StateorProvince |
The state in which the organization that created the WMS service resides. For example:
PostCode |
The postal code in which the organization that created the WMS service resides. For example:
Country |
The country in which the organization that created the WMS service resides. For example:
ContactVoiceTelephone |
The telephone number where the primary contact person for the WMS service can be reached. For example:
ContactFacsimileTelephone |
The fax number where the primary contact person for the WMS service can be reached. For example:
ContactElectronicMailAddress |
The email address where the primary contact person for the WMS service can be reached. For example:
Fees |
Text describing the fees imposed when accessing the WMS service. For example:
Access constraints |
Text describing the restrictions and legal prerequisites for accessing and using the WMS service.
SLD Path or URL |
SLDs allow you to publish multiple styles for each WMS layer. If you are binding an SLD file to the current WMS service, you need to enter the SLD path or URL property, network share, or physical location of an SLD XML file. The ArcGIS Server account must have access to the location for ArcGIS Server to properly read the SLD XML file. SLDs allow you to publish multiple styles for each WMS layer. If you are binding an SLD file to the current WMS service, you need to enter the SLD path or URL property to the URL, UNC path, or physical location of an SLD XML file. The ArcGIS Server account must have access to the location for ArcGIS Server to properly read the SLD XML file. To learn more about SLDs, see Using Styled Layer Descriptors with WMS services. |
Additional spatial reference systems |
This property can be used to add spatial reference systems to WMS services. By default, WMS services only list two spatial reference systems: EPSG:4326 (or CSR:84 for WMS 1.3.0) and the spatial reference of the map service on which the WMS is enabled. To list additional spatial reference systems, separate the spatial reference systems with a comma (,). For example, |
Custom spatial reference systems |
The
Identify tolerance (pixels) |
This property allows you to define a tolerance (in pixels) in which the |
Use layer names from the map document |
By default, this option is unchecked, meaning that layers in the WMS service will be represented with zero-based integers, indicating their position in the table of contents from the top down. Starting at version 10.8, there are no restrictions to the characters that can be used in a layer name, and WMS server will generate a unique identifier for the name when necessary. Note:The server assigned name will not affect the title. WMS server will assign a unique name by character substitution (replacing characters with an underscore) and by adding a numeric suffix. This will occur in the following instances:
Note:The suffix number is a computed value based on the original string and is not random. As such, it will remain the same as long as the layer name is unmodified. For example, if there are two layers named Layer "1" and Layer [1], both would be converted to Layer__1_. To differentiate between the two, a unique number would be appended as a suffix to the modified string. In this example, the modified layer names would be Layer__1_1234 and Layer__1_1256, respectively. |
Force map re-aspect based on width and height |
This property determines whether the map is re-aspected. By default, this option is deselected, which means that the pixels representing the map area are stretched to fit into the height and width requested by WMS clients. If this option is selected, the pixel height and width ratio will stay the same. When a map is requested at full extent, it may not fill the entire viewing area. |
Assign a name identifier to a layer |
By default, WMS services do not assign a < Name > to group layers. The |
inheritServiceLayerIDs |
Matches the layer identifier to the parent Map Service layer identifier. This property is unchecked by default. As such, the WMS service will be represented with zero-based integers, indicating their position in the table of contents from the top down. Beginning at version 12.1, the
Set properties in the Administrator Directory
Most properties can be configured using ArcGIS Server Manager. If a property cannot be modified using Server Manager, it can be modified or added using the ArcGIS Server Administrator Directory.
To edit properties using the directory, complete the following steps:
Open the Administrator Directory in a browser and log in.
The typical URL to the directory is
https://gisserver.example.com:6443/arcgis/admin/.Click services.
On the Folder page, click the name of the WMS-enabled map service that you want to edit.
If your service is not in the list, it may be in a subfolder under the root folder.
On the service's page, scroll to the bottom, and click edit.
On the Service Properties dialog box, locate the
"typeName": "WMSServer"section.In the
propertiessection, add the properties, and specify the necessary parameters.The following is an example:
"properties": { "name": "SampleWorldCities", "title": "WMS", "abstract": "", "keyword": "", "onlineResource": "", "contactPerson": "", "contactPosition": "", "contactOrganization": "", "address": "", "addressType": "", "city": "", "stateOrProvince": "", "postCode": "", "country": "", "contactVoiceTelephone": "", "contactFacsimileTelephone": "", "contactElectronicMailAddress": "", "fees": "", "accessConstraints": "", "customGetCapabilities": "false", "pathToCustomGetCapabilitiesFiles": "", "pathToCustomSLDFile": "", "listSupportedCRS": "", "listCustomCRS": "", "identifyToleranceInPixel": "10", "inheritLayerNames": "false", "reaspect": "true", "namedLayersMode": "subLayers", "inheritServiceLayerIDs": "false"S }Click Save Edits.
The properties are added to your WMS.
Special characters in service properties
The following characters cannot be included in any of the service properties: &, <, >, ", '. If you need to use one of these characters, you must substitute the appropriate escape sequence from the table below:
Character |
Character substitute |
Use external capabilities files with WMS services
Each WMS service exposes service-level metadata through its capabilities file. The capabilities file is the XML response that clients receive when they make a GetCapabilities request on the service. Configuring external capabilities files allows you to do the following:
Add metadata about the service.
Add metadata about each layer.
Customize the legend information for each layer.
To use external capabilities files with WMS services, you'll need to create the files and configure the files for use with your WMS services. The sections below describe this process.
By using external capabilities files for your WMS service, you are responsible for validating your capabilities files using the DTD or XML schema from OGC. You also assume responsibility for all the synchronization between your capabilities files and the source map document from which your WMS service is published.
Create external capabilities files
To configure a WMS service to use external capabilities files, you must prepare at least one WMS capabilities file. You can create the file from scratch, but it's often easier to use a system-generated capabilities file as a template.
By default, system-generated capabilities files are created automatically every time you send a WMS GetCapabilities request to the service. To use a system-generated capabilities file as a template, you need to manually send the GetCapabilities request and save the response as XML. If you want your WMS service to support different versions of WMS protocol—for example, 1.0.0, 1.1.0, 1.1.1, and 1.3.0—you must have one capabilities file for each version of WMS you want to support.
By default, the .xml files are stored at C:\Users\AppData\Local\Microsoft\Windows\INetCache\IE and are created every time a GetCapabilities request is made to that service.
You can change the location of the temporary .xml files to another drive or shared drive if the default directory is running low on space.
Complete the following steps to create external capabilities files for your WMS service:
If you haven't done so already, publish a map or image service and enable the WMS capability.
For more information, see WMS services.
In a web browser, provide the URL of your WMS service.
The URL is formatted as follows:
https://gisserver.example.com:6443/arcgis/services/folder/service/service type(can be MapServer or ImageServer)/WMSServerAppend ?service=wms&request=GetCapabilities&version=1.0.0 to the end of the service URL, and press Enter.
The XML displayed in the browser is the WMS version 1.0.0 capabilities file for your service.
Save the results as an
.xmlfile.The file name must follow the format
<prefix><WMS version>.xml. For example, when you save the result.xmlfile from a WMS version 1.0.0GetCapabilitiesrequest, the file must use a common prefix (such asRoads) followed by the three-digit WMS version number (100). The resulting file isRoads100.xml.Repeat steps 3 and 4 for each WMS version you want to support, for example, 1.1.0, 1.1.1, and 1.3.0.
Configure and customize metadata information for the WMS layers in each capabilities file.
Move all of the capabilities files into a common folder accessible through HTTP.
Typically, this will be a virtual directory on your organization's web server.
Configure a WMS service to use external capabilities files in ArcGIS Server Manager
To configure a WMS service to use external capabilities files by updating the WMS service to reference the URL of your capabilities files in ArcGIS Server Manager, complete the following steps:
Start ArcGIS Server Manager and sign in as an ArcGIS Server administrator.
If you need help with this step, see Log in to ArcGIS Server Manager.
In the capabilities list, click WMS.
In the WMS Configuration list, choose Use external capabilities files.
In the Specify the location and prefix text box, provide the URL of the folder where you placed your capabilities files and the common prefix you used for the files. For example, if the URL to the folder that contains your files is
https://webserver.example.com/arcgis/WMS/servicesand the common prefix you used isRoads, the URL to provide in the Specify the location and prefix text box ishttps://webserver.example.com/arcgis/WMS/services/Roads.Click Save and Restart.
