Backup and restore a cloud relational store
If ArcGIS Enterprise is deployed in the Amazon Web Services (AWS) or Microsoft Azure cloud and you use a cloud relational store, you have the following options for creating backups of the cloud relational store and restoring it:
  • Use the backup and restore functionality provided by your cloud platform, and update the cloud relational store information in ArcGIS Enterprise using the restoredatastore ArcGIS Data Store utility.
  • Schedule automatic ArcGIS Data Store backups and use the restoredatastore utility to recover.
  • Create on-demand backups using the backupdatastore ArcGIS Data Store utility and the restoredatastore utility to recover.
  • Use the webgisdr utility installed with Portal for ArcGIS to create backups and restore from them.
You can use any or all of these methods as part of your overall disaster recovery plan for ArcGIS Enterprise.
Use the backup and restore functionality of the cloud provider for data recovery
You can use the backup and restore functionality of your cloud database service provider. However, after you restore the database service instance, you must update the .json template with the new dbUri value and run the restoredatastore utility to update ArcGIS Enterprise with the new URI information.
By default, there are no automatic backups of the cloud relational store. Run the configurebackuplocation utility with the change option to update the default output location for cloud relational store backups.
It is recommended to use a file share for the default backup location.
./configurebackuplocation.sh --store relational --operation register --location <file-server-location>
configurebackuplocation --store relational --operation register --location <file-server-location>
Next, use the updatebackupschedule utility to define the backup schedule.
Use ArcGIS Data Store utilities to create backups on demand
This process is the same as for the relational store configured locally with the ArcGIS Data Store installation. Follow the instructions to register additional backup locations and manually create backups.
When you need to recover the cloud relational store using one of these backups, follow the instructions to restore the relational store after a crash.
Use this method to backup and restore the additional system stores installed and configured with the relational ArcGIS Data Store.
The webgisdr utility installed with Portal for ArcGIS allows you to create backups of all components of a base ArcGIS Enterprise deployment and restore that deployment using the backups it creates. See Create an ArcGIS Enterprise backup and Restore ArcGIS Enterprise for more information.
