Configure a database connection for ArcGIS Server
The sections below summarize using a supported database or cloud data warehouse with an ArcGIS Server site.
Configure clients and create a database connection file
The following topics provide instructions to install and configure client software and create a database connection file. Keep in mind that, when client software is required, you must install a release of the client software that is compatible with the release of the database to which you will connect.
Reference the database client libraries in the init_user_param.sh script
For most databases, you need to reference the database client libraries in the ArcGIS Server init_user_param.sh script. This process is described in the help pages referenced in the previous section, but a summary of the entries for all supported databases and cloud data warehouses is provided below.
PostgreSQL client libraries are installed with ArcGIS Server and no entry is needed for PostgreSQL in the
init_user_param.shfile.No entry is necessary in the
init_user_param.shfile for connections to Microsoft SQL Server from ArcGIS Server on Linux.Before adding the reference to the
init_user_param.shfile, ensure that the ArcGIS Server installation owner has at least read and execute permissions on the database client libraries.For settings to take effect in the init_user_param.sh script, you must restart ArcGIS Server on each machine in the ArcGIS Server site.
Edit the section that is relevant to your database management system by referencing the database client libraries and other database variables. To enable the variables, remove # from the lines beginning with export.
Dameng
# Modify this section to configure a connection to Dameng.
export DAMENGDIR=<Dameng_InstallDir>
export LD_LIBRARY_PATH=$DAMENGDIR/bin:$LD_LIBRARY_PATH
Google BigQuery
# Modify this section to configure an ODBC connection to Google BigQuery Data
# Warehouse.
# To make a connection, copy GoogleBigQueryODBC.did to the lib folder under the
# extracted directory for Google BigQuery ODBC driver. Edit
# simba.googlebigqueryodbc.ini and set DriverManagerEncoding=UTF-16. Configure and
# store the odbcinst.ini in the /etc folder.
export LIB_ODBC_DRIVER_MANAGER=<Location_to_ODBC_driver_manager_libraries>/libodbc.so.2
export SIMBAGOOGLEBIGQUERYODBCINI=<Location_to_simba.googlebigqueryodbc.ini>/simba.googlebigqueryodbc.ini
IBM Db2
# Modify this section to configure a connection to Db2
export DB2_CLIENT_HOME=<DB2_InstallDir>
export DB2INSTANCE=<DB2_instance_name>
export PATH=DB2_CLIENT_HOME/bin:$PATH
export LD_LIBRARY_PATH=$DB2_CLIENT_HOME/lib64:$LD_LIBRARY_PATH
Oracle
# For connection with Oracle Runtime or Administrator Client
export ORACLE_BASE=<Oracle_Installdir>/app
export ORACLE_HOME=$ORACLE_BASE/<Oracle_release>/product/<Oracle_version>/<client_version>
export ORACLE_SID=<set when applicable>
export TNS_ADMIN=<set when applicable. e.g.$ORACLE_HOME/network/admin>
export PATH=$ORACLE_HOME/bin:$PATH
export LD_LIBRARY_PATH=$ORACLE_HOME/lib:$LD_LIBRARY_PATH
If you have installed multiple Oracle clients, you will see multiple Oracle client folders. Ensure the ORACLE_HOME variable is set to the folder you intend to use to connect to the database in ArcGIS Server.
If you use the Oracle database instant client libraries, only the $LD_LIBRARY_PATH needs to be referenced, for example:
# For connection with Oracle Instant Client
export LD_LIBRARY_PATH=<Location_to_instantclient_11_2>:$LD_LIBRARY_PATH
Redshift
# Modify this section to configure Amazon Redshift ODBC connector
export AMAZONREDSHIFTODBCINI=<Location_to_amazon.redshiftodbc.ini>/amazon.redshiftodbc.ini
SAP HANA
# Modify this section to configure a connection to SAP HANA.
# To make a connection, name the SAP HANA ODBC configuration files as .odbcinst.ini
# and .odbc.ini and store them in the ArcGIS Server user $HOME directory.
export SAPHANADIR=<SAPHANA_InstallDir>/sap/hdbclient
export LD_LIBRARY_PATH=$SAPHANADIR:$LD_LIBRARY_PATH
Snowflake
# Modify this section to configure a connection to Snowflake Data Warehouse
Teradata or Vantage Advanced SQL Engine
# Modify this section to configure a connection to Teradata.
# To make a connection, name the Teradata ODBC configuration files as
# .odbcinst.ini and .odbc.ini and store them in the ArcGIS Server user $HOME directory.
export LIB_ODBC_DRIVER_MANAGER=<Teradata_InstallDir>/<version>/14.00/odbc_64/lib/libodbc.so
export TDDIR=<Teradata_InstallDir>/client/<version>/odbc_64
export LD_LIBRARY_PATH=$TDDIR/lib:$LD_LIBRARY_PATH
export ODBCINI=<Location_to_.odbc.ini>/.odbc.ini
Test the connection
To test a connection, publish a service using data residing in the database.
If you encounter problems with your connection, consult the server logs for more information. To learn about server logging, see Work with server logs.
If your user profile on the ArcGIS Server machines references the database client libraries, and the information in your user profile differs from what is set in the init_user_param.sh file, you may experience problems when attempting to connect to the database. To alleviate connection issues, remove the reference information from your user profile and use only the init_user_param.sh file to define database client information.
