Stream Link
License:
Available with Image Server
The Stream Link tool assigns unique values to sections of a raster linear network between intersections.
The output is a hosted imagery layer.
Learn more about identifying stream networks
Examples
Example scenarios for the use of this tool include the following:
Analyze a stream network by assigning unique IDs to the stream links.
Create a stream link result to be used as input to the Watershed tool, quickly creating watersheds based on the stream junctions.
Usage notes
Stream Link includes configurations for input layers and the result layer.
Input layers
The Input layers group includes the following parameters:
Input stream raster is the linear stream network that will be used for analysis. It can be created by assigning a threshold value to the results of the Flow Accumulation tool.
The linear stream network should be represented as values greater than or equal to one on a background of NoData.
Input flow direction raster is the direction of flow out of each cell.
The flow direction must have been determined using the D8 method.
Result layer
The Result layer group includes the following parameters:
Output raster name is the name of the output raster that contains the stream link result.
The name must be unique. If a layer with the same name already exists in your organization, the tool will fail and you will be prompted to use a different name.
Save in folder specifies the name of a folder in My content where the result will be saved.
Limitation
The Stream Link tool only supports a D8 input flow direction raster layer.
Environments
Analysis environment settings are additional parameters that affect a tool's results. You can access the tool's analysis environment settings from the Environment settings parameter group.
This tool honors the following analysis environments:
The default processing extent for raster analysis tools and raster functions is Display extent. This default is different from other types of analysis.
Output
The output is a raster with the linear stream network after unique values are assigned to sections between intersections.
Usage requirements
This tool requires the following user type and configurations:
Creator, Professional, or Professional Plus user type
Publisher or Administrator role, or an equivalent custom role
ArcGIS Image Server configured for raster analysis
Resources
Use the following resources to learn more:
Stream Link in ArcGIS REST API
stream_link in ArcGIS API for Python
Stream Link in ArcGIS Pro with the Raster Analysis extension
Stream Link in ArcGIS Pro with the ArcGIS Spatial Analyst extension
