Configure time settings
Spatial phenomena collected with time information can allow you to see what happened at a specific time or what may happen in the future. By animating time-based data, you can visualize it at each step and see patterns or trends emerging over time. Examples of phenomena with data that are well suited for this purpose include hurricanes, tornadoes, and other meteorological events; population migrations; land-use and environment change; and wildfire or flood event progression.
Some map layers are time-enabled; they contain spatial datasets that include different information for the same location at different times. If a map contains time-enabled layers, it is time aware, and you can configure it to set the map time zone, display the data during a specific period of time, or animate the data over time.
Verify time data in a layer
You can determine whether a layer in a map is time-enabled by referring to the item details for the layer.
  1. Confirm that you are signed in and, if you want to save your changes, that you have privileges to create, update, and delete content.
  2. On the Contents (dark) toolbar, click Layers to open the Layers pane.
  3. Browse to the layer that contains time data, click Options , and click Show properties.
  4. In the Properties pane, click Information, and click the item to open the item page.
  5. On the Overview tab, scroll to the Layers section and click the name of the layer to open its item page.
    If the layer contains temporal data, a Time settings option is included in the Layers section.
Enable time on layers
You can set time properties on feature and imagery layers in ArcGIS Pro before you publish a feature layer, imagery layer, or map image layer (map service) to ArcGIS Enterprise. You can configure these time-enabled web layers to display time animation when you add them to Map Viewer. If you have sequential data in which each field represents a separate time, you can configure time series animation using an ArcGIS Arcade expression to show a progression of events over time.
You can also publish hosted feature layers that include temporal data and enable time on them from the layer's item page. This allows you and your organization (if you share your feature layers) to use the temporal data to create time-enabled maps.
To enable time on hosted feature layers, the hosted feature layer owner or an administrator can follow these steps:
  1. On the My Content tab of the content page, open the item page for a hosted feature layer with temporal data.
  2. In the Layers section on the Overview tab, click Time Settings.
  3. Check the Enable time check box.
  4. Choose specific events in time or time ranges with a start and end time to record the time data.
  5. Choose the field or fields in the data.
    Supported date and time field types include the following:
    • Date
    • Date only
    To learn more about supported field types, see Date and time fields in ArcGIS Enterprise.
    When working with time ranges with a start and end time, you must select the same field type for both Start time field and End time field.
  6. Click OK.
When this hosted feature layer is added to Map Viewer, time animation is enabled.
Configure time series animation
You can also enable time on certain layers by using a time series Arcade expression to create animations from sequential temporal fields. Time series expressions can be applied to data in which each field represents a distinct time. For example, if you have population data by year for municipalities throughout a region, you can use a time series expression to visualize population change over time.
To create a time series Arcade expression, do the following:
  2. In Map Viewer, open the map containing the layer or add the layer directly.
  3. In the Layers pane, click the layer to select it.
  4. In the Styles pane, under Choose attributes, click Expression.
  5. In the Arcade expression editor window, click Suggestions .
  6. Under Suggestions, click Time series.
    To configure a time series visualization, your data should be structured in wide table in which each row represents a static feature with a fixed location, such as a country boundary or a city location. The table should have two or more fields, or columns, that represent the same data attributes at different points in time for each feature. Field names should refer to a specific attribute and a specific point in time at regular intervals, such as sequential months or 10-year intervals. For example, a layer containing city locations in which each row represents a city with the following field structure could be used to configure a time series visualization:
    • CITY_NAME
    • POPULATION_1990
    • POPULATION_2000
    • POPULATION_2010
    • POPULATION_2020
    For more information on creating an animation from sequential temporal fields, next to Time series, click Expand to view additional Arcade documentation and learn more about supported field name patterns for time series expressions.
    The time series Arcade expression is added to the expression builder pane.
  7. Follow the steps outlined in the time series expression code to modify the expression using temporal fields present in your data layer.
  8. Click Done to apply the expression and return to the Styles pane.
    Tip:
    The time series expression used to apply styling can also be used to configure pop-ups and labeling. When configured, pop-ups and labels will update with the time slider.
    The time slider and time slider options opens with a warning that the time series requires a valid date range, prompting you to configure start and end dates.
  9. In the Time slider options window, under Start and end points, configure start and end dates to match the dates of the first and last fields you are using for the time series animation.
  10. In the Time slider options window, under Time intervals, configure the intervals in the time slider to match the intervals in the data.
    If the intervals configured in the Time slider options window are different from those in the data, the time series animation may not display correctly.
  11. In the Styles pane, use style options to change the symbol style. Verify the minimum and maximum values for the fields used in your time series animation and adjust the data range to match.
    You may need to manually update the data range used to style the data to ensure all values display on the map.
  12. In the Style options pane, click Done when you finish customizing your style, or click Cancel to return to the Styles pane without saving your choices.
  13. In the Styles pane, click Done.
  14. On the Contents (dark) toolbar, click Save and open and click Save to save your styling changes to the map and layer item.
  15. Configure time slider options in a map as described below or see View time maps (Map Viewer) to view your time series animation.
Set the map time zone
You can set the time zone of a map to customize how date and time are displayed in places such as pop-ups and tables.
To set the time zone, complete the following steps:
  2. In Map Viewer, open the map containing time-enabled layers or add layers to a new map.
  3. On the Contents (dark) toolbar, click Map properties .
  4. Under Time zone, choose one of the following:
    • Select Device time zone to display the date and time using the time zone set for the device used to view the map.
    • Select Specific time zone to display the date and time according to the time zone selected by the map author.
    • Select Data's time zone to display the date and time based on the time zone that has been defined for the layer. No adjustments are made to the display of date info.
      Options to configure time slider settings are disabled when using this time zone option.
      Tip:
      To view the time zone set for the map, click Time zone label .
You can configure the time slider options to customize how time-enabled layers are displayed in a map.
  3. On the Contents (dark) toolbar, click Map properties , and click Time slider options.
    You can also open the Time slider options pane by selecting the time-enabled layer and clicking Time on the Settings (light) toolbar. Click Options on the time slider and click Time slider options . Optionally, on the Settings (light) toolbar, click Time to show and hide the time slider.
  4. Make any of the configurations described in the subsections below.
  5. On the Contents toolbar, click Save and open and click Save to save the time settings to the map.
Use the Time display drop-down menu to specify the time period for the time-enabled layer. Choose one of the following:
  • Show data within interval—Show data that falls within the current time interval.
  • Show features progressively—Progressively show data that is within a set time range. The start time is always pinned to the start of the slider.
Time intervals
Specify how much data to display as time passes. Choose Length of one interval to specify the count and units for each time interval, or choose Total time divided into equal steps and specify the number of intervals.
Playback position
Choose whether to start the time animation at the beginning of the time span or at the time position last saved with the map.
Play rate
Set the speed at which the time intervals play. You can move the slider to increase and decrease the speed.
Enable time-based layer visibility
For all layers, you can set a specific time period during which the layer is visible. To enable time-based layer visibility, complete the following steps:
  3. In the Layers pane, click a layer to select it.
  4. On the Settings (light) toolbar, click Properties .
  5. Under Time, turn on the Time-based layer visibility toggle button. Under Start and End, set the date and time ranges to define the time period during which the layer is visible.
Turn off time animation
You can turn off time animation on maps containing time-enabled layers. To turn off time animation on a web map, complete the following steps:
  3. On the Contents (dark) toolbar, click Layers to open the Layers pane.
  4. Select the time-enabled layer.
  5. On the Settings (light) toolbar, click Properties .
  6. Turn off the Enable time toggle button.
  7. Repeat the previous steps for each time-enabled layer.
