Publish hosted feature layers
As a publisher in your organization, you can host feature data in ArcGIS Enterprise by publishing hosted feature layers. ArcGIS Enterprise supports multiple sources to allow you to accomplish this. Use any of the following to publish a hosted feature layer:
You can also define a blank hosted feature layer and the empty layers it contains. After the hosted feature layer is created, add fields to each layer.
Feature layers are useful when you need to expose vector data for display, query, and editing to other members of your organization or when you want to share a table of nonspatial attributes. Hosting a feature layer on ArcGIS Enterprise is one way to share data with coworkers through maps, apps, and desktop map viewers.
Feature layers are most appropriate for operational layers—the layers with which you interact—that go on top of reference layers, such as a basemap. For example, a feature layer may contain information about the street signs in your neighborhood. Each feature (street sign) may include the sign name, date installed, and a website URL for reporting problems to your local street department.
Tip:
By default, only 2,000 records are returned at a time when drawing or querying a feature layer. After publishing a hosted feature layer, publishers and administrators can update the maximum record limit from the service properties in ArcGIS Server Manager. Connect to the hosting server and set the Maximum Number of Records Returned by Server property to the desired value for each service.
To complete the steps in the following sections, you must have privileges to publish hosted feature layers and create, update, and delete content.
Publish a CSV file
If you have CSV files stored on your computer that contain addresses or coordinates, you can sign in to the organization and publish features or tables from the CSV files. The resultant feature layer is published as a service to your hosting server. These services are referred to as hosted feature layers.
The steps below outline how to publish features or tables from the portal website using a CSV file.
These files do not enforce unique field names, but field names in hosted feature layers must be unique. Therefore, ensure all field names in your file are unique before publishing.
The features are published in the WGS 1984 Web Mercator (Auxiliary Sphere) coordinate system.
The following steps explain how to add a CSV file from your local drive and publish.
  1. Verify that you are signed in and that you have privileges to create, update, and delete content and publish hosted feature layers.
  2. Open Content > My content, click New item, and click Your device.
    Instead of clicking Your device and browsing to the file, you can drag the file onto the window from a file browser on your local machine.
    If you do not click Your device or drag the file onto this window, you can click Feature layer and then click Upload a file > Your device.
  3. Find the file on your device or a machine on your network.
  4. Select the file and click Open.
    CSV files must be formatted and saved as .csv.
  5. Choose Add <file name> and create a hosted layer or table.
  6. Click Next.
  7. Review the included fields and make changes as needed.
    If the field types can be identified, they are set automatically, but you can change field types.
  8. If the file contains one or more date fields, optionally choose a time zone from the Time Zone drop-down menu.
    By default, date fields are assumed to contain UTC date and time. If your date fields store values that use a different time zone, choose that time zone. The time zone that you select is applied to all date fields in the file. If you later overwrite the hosted feature layer using updated data, the time zone specified when you initially published is used.
    See CSV files for information about time zone considerations and supported date and time formats.
    Tip:
    You can configure pop-ups to display time.
  9. Click Next.
  10. Choose the information in your file to use to locate features.
    • If your file contains coordinates, choose whether to use Latitude and longitude, Military Grid Reference System (MGRS), or United States National Grid coordinates.
    • Choose Addresses or place names if your file contains place-names—for example, Westminster Abbey or Panama Canal—or addresses.
    • To create a nonspatial table layer, choose None.
  11. If you are locating features based on Addresses or place names and your organization has multiple locators configured, click Advanced location settings and choose the locator to use.
    Your portal must be configured to use a locator (geocode utility service) that can do batch geocoding for you to publish a CSV file containing addresses. Contact your organization administrator if the option to publish is not available when you add your file.
  12. If your file contains addresses, click Advanced location settings and use the Region drop-down list to specify the country in which the addresses are located. If your file contains addresses from multiple countries or from a country not in the list, select World.
    By default, the locator adds a field that stores the coordinate location for each feature. You can include additional fields that provide you with information related to the geocoding process, such as how closely the location information in your input file matches with a location in the locator service.
  13. Choose whether the location information is based on one or multiple fields.
  14. Click Next.
  15. Type a title.
  16. Choose a folder in My content where you want to save the item.
    Alternatively, you can choose Create new folder from the menu and type a folder name to save the item in a new folder.
  17. If your organization administrator configured content categories, click Assign categories and select up to 20 categories to help users find the item.
    You can also start typing a category name to narrow the list of categories.
  18. Optionally, type tag terms separated by commas.
    Tags are words or short phrases that describe the item and help users find the item when searching. Federal land is considered one tag, while Federal,land is considered two tags.
  19. Optionally, type a summary that describes the data.
  20. Click Save.
The data file and the feature layer are separately added to My content. One way to test the new hosted feature layer once publishing completes is to view it in a map viewer.
By default, only you and organization administrators can access the hosted feature layer. To allow others to access it, share the layer and file with everyone (the public), your organization, or members of specific groups. You can edit item details and change feature layer settings.
To share the hosted feature layer as a copy in a distributed collaboration, you must enable synchronization.
Publish an Excel file
You can upload an Excel file (.xlsx or .xls) to the portal and publish a hosted feature layer from one of the worksheets. If the worksheet contains latitude and longitude information, place-names, or addresses, you can publish a hosted feature layer from the worksheet. If no spatial information is present in the worksheet, you can publish a hosted table.
The following steps explain how to add an Excel file from your local drive and publish.
  6. If your file contains multiple worksheets, choose the one to publish from the Publish this sheet drop-down list.
    By default, the first sheet in the spreadsheet is published.
  7. Click Next.
  8. Review the fields included and make changes as needed.
  9. Choose a time zone from the Time Zone drop-down menu for the date fields in the file.
    By default, date fields are assumed to contain UTC date and time. If the date fields in the file store values that use a different time zone, choose that time zone.
    Tip:
  10. Choose the information in the file to use to locate features.
    Your portal must be configured to use a locator (geocode utility service) that can do batch geocoding for you to publish an Excel file containing addresses. Contact your organization administrator if the option to publish is not available when you add the file.
    If your file contains addresses from multiple countries or from a country not in the list, choose World.
  13. Choose whether the locations are based on one or multiple fields.
  14. Review the location fields, if any exist.
    If ArcGIS Enterprise can identify which fields contain location information, it sets them automatically. However, you can change location fields if necessary by clicking inside the cell.
  15. Click Next.
  16. Type a title.
  17. Choose a folder in My content where you want to save the item.
  18. If your organization administrator configured content categories, click Assign categories and select up to 20 categories to help users find the item.
  19. Optionally, type tag terms separated by commas.
  20. Optionally, type a summary that describes the data.
  21. Click Save.
Publish a shapefile
To web enable feature layers from shapefiles (packaged in a .zip file), upload the .zip file to your organization and publish. This creates an item for the shapefile and creates a hosted feature layer.
Follow these steps to publish a hosted feature layer from a .zip file containing a shapefile or shapefiles:
    Shapefiles must be compressed as a .zip file containing .shp, .shx, .dbf, and .prj files.
    If there are multiple shapefiles in the .zip file, they are all included in the hosted feature layer.
  5. When you add a .zip file, specify the type of content in the file. Choose the data format from the Item type drop-down menu.
    You cannot upload the file if the wrong content type is specified.
  6. Choose Add <file name> and create a hosted layer.
  7. Click Next.
  8. Type a title.
  9. Choose a folder in My content where you want to save the item.
  10. If your organization administrator configured content categories, click Assign categories and select up to 20 categories to help users find the item.
  11. Optionally, type tag terms separated by commas.
  12. Optionally, type a summary that describes the data.
  13. Click Save.
If you publish a shapefile or shapefiles that contain metadata, that metadata is included in the layers in the hosted feature layer. When viewed from the hosted feature layer's item page, the metadata is displayed in the metadata style configured for the organization.
Publish a GeoJSON file
You can publish from a GeoJSON file on a local drive or access a GeoJSON file on the web to publish a hosted feature layer from the file.
Publish from a local file
To web enable feature layers from a GeoJSON file (.geojson or .json), add the file to your organization and publish. The resultant feature layer is published as a service hosted in ArcGIS Enterprise. These services are referred to as hosted feature layers.
To publish, the GeoJSON file must be smaller than 100 MB.
The steps below outline how to publish features from the portal using a GeoJSON file.
  5. Choose Add <file name> and create a hosted layer.
  6. Click Next.
  7. Type a title.
  8. Choose a folder in My content where you want to save the item.
  9. If your organization administrator configured content categories, click Assign categories and select up to 20 categories to help users find the item.
  10. Optionally, type tag terms separated by commas.
  11. Optionally, type a summary that describes the data.
  12. Click Save.
Publish from a file on the web
If you have access to a GeoJSON file on the web, you can use the URL to the GeoJSON fiile to publish a hosted feature layer from it.
If the file is larger than 50 MB, creating a hosted feature layer from the file URL may not be supported.
To create a hosted feature layer from a larger file, download the file and publish from the file instead of from the URL.
  1. Verify that you are signed in and have the privilege to create, update, and delete content.
  2. From the My content tab of the Content page, click New item and click URL.
  3. Provide the REST URL of the GeoJSON file on the web.
    The following is an example GeoJSON file on the web that is available to the public: https://earthquake.usgs.gov/earthquakes/feed/v1.0/summary/4.5_week.geojson
  4. Choose GeoJSON for the item type.
  5. Click Next.
  6. Choose the Add data and create a hosted feature layer option.
  7. Click Next.
  8. Provide a title.
    Alternatively, choose Create new folder from the menu and provide a folder name to save the item in a new folder.
  11. Optionally, provide tags that describe the item.
    Separate the terms with commas (for example, Federal land is considered one tag, and Federal, land is considered two tags).
    As you type, you can choose any of the suggested tags that appear; suggestions are generated from tags you previously added.
  12. Optionally, provide a summary that describes the item.
  13. Click Save.
After you add the GeoJSON file from the web using its URL and publish, the hosted feature layer item appears in your content, and you can edit the item details and share it if you have sharing privileges.
Publish the contents of a file geodatabase
You can sign in to the portal website and publish a feature layer from a file geodatabase (packaged in a .zip file).
Publishing file geodatabase contents is a useful workflow if the geodatabase contains only a few datasets. Each feature class in the file geodatabase will be a layer in the hosted feature layer.
You can publish the following data types from a file geodatabase to a hosted feature layer:
  • Feature classes (x- and y-coordinates; m- and z-coordinates are dropped)
  • Tables
  • Attachments
  • Relationship classes
Other data types—such as rasters and networks—remain in the geodatabase but are not included in the published hosted feature layer.
  • The features are published in the WGS 1984 Web Mercator (Auxiliary Sphere) coordinate system.
  • Shared templates defined for the feature classes and tables in the geodatabase will be included in the hosted feature layer.
Follow these steps to add a file geodatabase to the portal and publish its contents as a hosted feature layer.
  3. Find the file on your device or network.
    The file geodatabase must be in a .zip file.
  7. Click Next.
  8. Type a title.
  13. Click Save.
The supported data in your file geodatabase is published as a hosted feature layer. It may take some time to upload the file and publish. When publishing completes, you can test the new feature layer by viewing it in Map Viewer. Views in the file geodatabase are not published but remain in the file geodatabase.
If the feature classes in the file geodatabase contain metadata, that metadata is included in the layers in the hosted feature layer. For each layer that has metadata, you can view the metadata from the hosted feature layer's item page, and the metadata is displayed in the metadata style configured for the organization.
Publish photos with locations
You can upload a compressed file (.zip file) containing photos that have geotags, and publish a hosted feature layer. ArcGIS Enterprise creates points in the hosted feature layer based on the GPS information in each photo's geotag. The photos are stored as attachments to these points. No point is created for any photo in the file that does not include GPS information.
You can upload a .zip file that contains JPEG image files that are tagged using standard Exchangeable Image File Format (EXIF) GPS information only.
Follow these steps to add a collection of images and publish a point hosted feature layer with the images stored as attachments.
    The images must be in a .zip file.
  4. When you add a .zip file, specify the type of content in the file. Choose the data format from the Item type drop-down menu.
  5. Select the file and click Open.
  7. Click Next.
  8. Type a title.
  13. Click Save.
A point for each geotagged photo is created in the hosted feature layer. When publishing completes, you can test the new feature layer by viewing it in Map Viewer.
Publish the contents of an OGC GeoPackage
You can upload an OGC GeoPackage file and publish its contents as a hosted feature layer. One layer will be created in the hosted feature layer for each spatial table in the GeoPackage.
Publishing the contents of a GeoPackage is a useful workflow if the GeoPackage contains only a few tables.
The following data types will publish:
  • Spatial tables that store point, multipoint, line, multiline, polygon, or multipolygon features
  • Nonspatial tables
Other data types in the GeoPackage file, such as tile pyramids and views, will not be included in the hosted feature layer.
Follow these steps to add a GeoPackage file to the portal and publish its contents as a hosted feature layer:
  3. Find the GeoPackage file on your device or network.
  5. Choose Add <file name> and create a hosted feature layer.
    If, instead, you add the file but don't publish a hosted feature layer, you can publish later from the GeoPackage item's page.
  6. Click Next.
  7. Type a title.
  12. Click Save.
The supported data in the GeoPackage file is published as a hosted feature layer. It may take awhile to upload the file and publish. When publishing completes, you can test the new feature layer by viewing it in Map Viewer.
Publish from a service definition file
You can upload a service definition file (.sd) that you create in ArcGIS Pro to publish features to ArcGIS Enterprise. For more information, see Publish a service definition.
If the service definition file contains shared templates, they will be included in the hosted feature layer.
Publish a feature collection
If your data needs to be edited by multiple people, you can publish a feature collection as a hosted feature layer, share the layer, enable editing on it, and use the feature layer in a map.
If you alter symbology for individual points in the feature collection, that symbology change is not preserved when you publish the feature collection as a hosted feature layer.
  1. Open the item page of the feature collection.
  2. Click Publish.
  3. Use the default title for the hosted feature layer or provide a new one.
  4. If your organization administrator configured content categories, click Assign categories and select up to 20 categories to help users find the item.
  5. Optionally, provide tag terms separated by commas.
    Tags are words or short phrases that describe your item and help people find your item when searching. public buildings is considered one tag, while public,buildings is considered two tags.
  6. Click Publish to create the hosted feature layer.
A hosted feature layer is created and added to your content.
Now you can share the hosted layer, enable editing, and add the feature layer to a map.
Publish from ArcGIS Pro
When you publish a feature layer to ArcGIS Enterprise from ArcGIS Pro with the option to copy data, a hosted feature layer is created, feature data is copied from your source to ArcGIS Enterprise, and the hosted feature layer references the data that was copied, not the data source.
Instructions for publishing a hosted feature layer from ArcGIS Pro are available in the ArcGIS Pro help.
If the layers in the ArcGIS Pro map have definition queries applied to them, ArcGIS applies the definition queries to the published hosted feature layer. However, all data is copied to ArcGIS Enterprise. To publish a subset of the data, you must export the subset to another feature class and publish that.
If you intend to overwrite the hosted feature layer to update it, be sure to choose the Preserve layer IDs option when you publish the feature layer from ArcGIS Pro.
Define your own layer
When you define your own layer, ArcGIS Enterprise creates a blank hosted feature layer containing the layers and tables you define.
  1. Verify that you are signed in with an account that has privileges to create, update, and delete content and publish hosted feature layers, and click the My content tab of the Content page.
  2. Click New item and choose Feature layer.
  3. Choose Define your own layer and click Next.
  4. Provide a name for the first layer in the feature layer and choose what type of layer to create: Point layer, Line layer, Polygon layer, Multipoint layer, or Table.
  5. To add more layers to the feature layer, click Add and repeat the previous step for each layer.
    Clicking Add places a new layer at the top of the list of layers. The order of the layers as they appear in this window is how the layers will appear in the hosted feature layer. Therefore, add layers in reverse order to how you want them to appear in the hosted feature layer.
  6. Optionally, enable the Add GPS metadata fields toggle button if the layers need to store GPS information such as receiver name, accuracy, and fix type.
    When you edit the layer in the ArcGIS Field Maps mobile app, GPS metadata is recorded automatically. For more information about GPS metadata, see Prepare for high-accuracy data collection in the ArcGIS Field Maps help.
  7. To store z-coordinates with the layers, enable the Enable Z-values toggle button.
  8. To store m-values (measures) with the layers, enable the Enable M-values toggle button.
  9. When you finish adding the layers and tables you want in the hosted feature layer, click Next.
  10. Type a title.
  11. Choose a folder in My content in which to save the hosted feature layer.
  12. If your organization administrator configured content categories, click Assign categories and select up to 20 categories to help users find the item.
  13. Optionally, type tag terms separated by commas.
  14. Optionally, type a summary that describes the data.
  15. Click Save to create the feature layer.
When the feature layer is created, its item page appears.
Next, add fields to each layer and table, define attribute lists and ranges, define feature templates, and configure other settings that you require.
By default, editing is enabled on the new hosted feature layer, making it ready for data collection. If you don't want other people to edit it yet, disable editing by unchecking the Enable editing check box on the Settings tab of the hosted feature layer's item page.
Create from a template or existing feature layer
To duplicate layer properties while allowing members of your organization to populate the new layer with new features, create a hosted feature layer from an existing hosted feature layer, ArcGIS Server feature layer, or a template. When you do this, the fields from the existing layer or template are used in your new hosted feature layer, but the attributes (rows) are empty in the new layer.
For example, you may have a feature layer displaying the perimeter of an existing wildfire. When a new wildfire occurs, you can create an empty feature layer from your existing one. The new layer will have the same fields present, such as date_reported, percent_contained, and fire_crews_assigned, but the fields will not be populated. You can then populate the new layer with the boundary and attributes of the new wildfire.
To create a hosted feature layer from a template or another feature layer, follow the steps below:
  3. Choose an existing feature layer or template that contains the layers and schema to apply to the new feature layer.
    This step doesn't add or copy any features to the new hosted feature layer; you're only defining the layers and schema of the new hosted feature layer.
    If the existing feature layer or template includes m-values or z-values, the hosted feature layer you create will also have m- and z-values enabled. Similarly, if the existing feature layer or template has a default z-value, the hosted feature layer you create will use the same default z-value.
    There are several approaches you can take, as described below:
    • Click Select an existing feature layer, click Next, choose the existing feature layer you want to use as a template, and click Next.
    • Click Use a template, click Next, choose a template provided by Esri, and click Next.
    • Click Provide an ArcGIS Server layer URL, click Next, provide the URL of the existing ArcGIS Server feature layer to use as a template, and click Next.
  4. No matter which approach you choose, check the box next to each layer you want to include in the new feature layer.
    You must include at least one layer.
  5. When you finish choosing layers, click Next.
  6. To add GPS metadata fields to layers and store GPS information such as receiver name, accuracy, and fix type to the feature layer, enable the Add GPS metadata fields toggle button.
    Because GPS metadata fields require attachments, the line or polygon layers you create will automatically have attachments enabled if you enable the Add GPS metadata fields option.
    When you edit the layer in ArcGIS Field Maps mobile app, GPS metadata is recorded automatically. For more information about GPS metadata, see Prepare for high-accuracy data collection in the ArcGIS Field Maps help.
  9. Click Next.
  10. Provide a title for the new hosted feature layer.
  11. If your organization administrator configured content categories, click Assign categories and select up to 20 categories to help users find the item.
  12. Choose the folder in which to store the new hosted feature layer.
  13. Optionally, provide tags and a summary for the new hosted feature layer.
  14. Click Save to publish the new layer.
    The item page of the new hosted feature layer appears.
If you used a template, editing and synchronization are enabled by default on the new hosted feature layer, making it ready for data collection. If you don't want other people to edit it immediately, disable editing by unchecking the Enable editing check box on the Settings tab of the hosted feature layer's item page.
If you used an existing feature layer, the new hosted feature layer has the same editing settings as the source feature layer.
