Feature layers
A feature layer is a grouping of similar geographic features, for example, buildings, parcels, cities, roads, and earthquake epicenters. Features can be points, lines, or polygons (areas). Feature layers are most appropriate for visualizing data on top of basemaps. You can set properties for feature layers—such as style, transparency, visible range, refresh interval, and labels—that control how the layer appears in the map. Using a feature layer, you can view, edit, analyze, and run queries against features and their attributes.
Each type of feature layer meets a different need and, therefore, has slightly different functionality. For a comparison of functionality available with each type of feature layer, see Feature layer functionality.
For information on Open Geospatial Consortium (OGC) features, see OGC.
Layers in feature layers
Each feature layer item can contain one or more layers. These layers (also called sublayers) can each store different geometry types; for example, a parks feature layer item can contain a point layer representing trees, a line layer representing trails, and a polygon layer representing park buildings.
Sublayers can also represent different types of data, such as a catalog layer or an oriented imagery layer.
There are some settings, such as enabling attachments, that are always set on the sublayer. Other settings, such as metadata, can be different for a sublayer than for the feature layer item.
You can add sublayers individually to a map if you do not need every layer in the feature layer item. The exception is catalog layers—you cannot add them to a map. Because catalog layers are used to provide access to other data, they cannot be viewed on the Visualization tab in the feature layer's item page, and they are not included in hosted feature layer views.
Hosted feature layers
Hosted feature layers are feature services for which feature data is hosted by, or stored in, one of two system-maintained data stores.
You can think of the layer, service, and its data as a single entity. When you create a hosted feature layer, the data is copied into one of the system managed data stores. When the owner of the hosted feature layer or an administrator deletes a hosted feature layer, the service and data are also deleted.
The functionality available varies slightly depending on the data store the hosted feature layer accesses. You can identify the two types of layers based on the layer icon.
Hosted feature layers are created when you publish a feature layer to ArcGIS Enterprise from ArcGIS Pro or from files in the portal.
Hosted spatiotemporal feature layer
Hosted spatiotemporal feature layers are created when the app you're using requires both geographic and time data. In most cases, editors do not directly edit these layers; rather, the apps that require them create and update hosted spatiotemporal feature layers.
Hosted Indoors Spaces feature layers
When you publish a Reservations layer that conforms to the ArcGIS Indoors information model to an ArcGIS Enterprise organization that is licensed for Indoors Spaces, a hosted Indoors Spaces feature layer is created. Hosted Indoors Spaces feature layers are used to enable workspace reservations in Indoors Viewer and the Indoors mobile apps.
Hosted Indoors Spaces feature layers have similar functionality to other hosted feature layers when you interact with them in the portal, with the following exceptions:
Anyone who has access to an Indoors Spaces feature layer can edit it.
You cannot share Indoors Spaces feature layers with the public or distributed collaboration groups.
ArcGIS Server feature layers
If you have access to feature services running on a stand-alone or federated ArcGIS Server site, you can use these ArcGIS Server feature services as layers in your organization. These layers are similar to hosted feature layers with the following differences:
The data is not copied into a system-maintained data store; it stays in the data source you registered with the ArcGIS Server site. The exception is if you create a snapshot when publishing data from a cloud data warehouse; in that case, data is copied to a system-maintained data store.
If the source data is from a cloud data warehouse, you cannot enable editing on the ArcGIS Server feature layer.
Data is not deleted when you delete an ArcGIS Server feature layer. Again, the exception is data snapshots from cloud data warehouses.
Functionality available in the portal is different for ArcGIS Server feature layers than for hosted feature layers.
When you publish a feature layer (feature service) to a federated ArcGIS Server site, it is automatically added as a feature layer to your organization. If you want to work with a feature service from a stand-alone ArcGIS Server site, you can add it to your organization as an item. This allows you to reference the REST endpoint (URL) of the service and use the layer in maps and apps while leaving the data stored in the data sources you registered with the ArcGIS Server site. You can also add ArcGIS Server feature layers to Map Viewer.
Caution:
An ArcGIS Server feature layer and its associated map image layer are dependent items because the two items reference a map service with feature access enabled. This means that when you share the map image layer item, the underlying map service and feature service are accessible to the same audience, even if you did not share the feature layer item with that audience. However, the reverse is not true; if you share the feature layer item, you must also share the map image layer to the same audience. If you do not, users cannot access the feature layer item.
Layers in an ArcGIS Server map or feature service
You can add individual layers in a map service or feature service as an item or to a map in Map Viewer. This allows you to use a single layer in the service in a map or app instead of having to use all the layers in the service.
For example, if you have access to an ArcGIS Server map service that contains a roads layer, a buildings layer, and a railroads layer, but you only need to access the roads, you can add the roads layer as an item (recommended if you need to provide credentials to access the service) or directly to a map. To do this, you need to copy the roads layer's URL from the REST endpoint of the map service. The URL for a map service's REST endpoint is in the format https://<server>.<domain>/server/rest/services/<service_name>/MapServer. A link for each layer in the service is listed in the Layers section of this page. Click the link for the layer you want to use. Copy the URL of the page that opens to obtain the layer's URL.
Feature layers created from a layer in a map service are read-only; you cannot enable editing on them.
The following sections list how to create each type of feature layer and compare functionality available with each type in Map Viewer, Scene Viewer, and the item page.
Publishing methods
The following list describes how you create each type of feature layer in ArcGIS Enterprise:
Hosted feature layer—Add an item to the organization and publish, publish from ArcGIS Pro, create an empty hosted feature layer from a template or an existing feature layer, or define the schema for an empty hosted feature layer. See Publish hosted feature layers for more information.
Hosted spatiotemporal feature layer—Publish using ArcGIS GeoEvent Server. ArcGIS Tracker also creates a hosted spatiotemporal feature layer to track locations, and ArcGIS Mission creates spatiotemporal hosted feature layers to track missions.
ArcGIS Server feature layer—Publish from ArcGIS Pro to a federated ArcGIS Server site, publish from ArcGIS Pro to a stand-alone ArcGIS Server site and add the service to your organization, or publish from data store items in the portal.
Map Viewer
At this time, you can add a subset of feature layer types to Map Viewer. The available functionality for each layer type may differ slightly. The following table compares feature layer functionality in Map Viewer:
Functionality |
Hosted feature layer |
Hosted spatiotemporal feature layer |
ArcGIS Server feature layer |
Hosted Indoors Spaces feature layer |
Edit (if editing is enabled on the layer) |
Yes |
Yes |
Yes |
Anyone with access to the layer can edit it even if editing isn't enabled. |
Yes |
Yes |
Yes |
Yes |
Define labels |
Yes |
Yes |
Yes |
Yes |
Set refresh interval |
No |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Create group layers |
Yes |
Yes |
Yes |
Yes |
Use standard feature analysis tools |
No |
No |
No |
No |
Calculate fields in the attribute table |
Yes |
No |
No |
Yes |
Add fields to and delete fields from the attribute table |
Yes |
You can add fields but not delete fields |
No |
Yes |
Display features aggregated in bins |
No |
Yes |
No |
No |
Scene Viewer
You can add the following types of feature layers to Scene Viewer:
Each layer can contain an unlimited number of features.
Item page
Many of the settings and details you configure for feature layers are the same for all portal items. Settings and details that are different across feature layers are listed in the following table:
Functionality |
Hosted feature layer (including Indoors Spaces feature layer) |
Hosted spatiotemporal feature layer (created by ArcGIS GeoEvent Server) |
Feature collection |
Publish other layers from |
Yes, WFS and tile layers |
No |
No |
No |
Yes, a hosted feature layer |
Create views from |
Yes |
Yes |
You cannot create views from the feature layer in the portal, but the equivalent workflow is to publish multiple feature layers from the same data in ArcGIS Pro. |
No |
No |
Define view areas on the Visualization tab |
Yes |
Yes |
Not applicable |
Not applicable |
Not applicable |
Export data from |
Yes |
No |
Yes |
No |
No |
Add and view metadata |
Yes |
Yes |
Yes |
No |
Yes |
Yes |
No |
You cannot enable attachments for the layer in the portal. However, you can enable attachments on the source data before publishing the feature layer. |
No |
No |
Yes |
No |
You cannot overwrite the layer in the portal. However, you can overwrite from ArcGIS Pro. |
No |
No |
Append data |
Yes You can also use the Append geoprocessing tool in ArcGIS Pro. |
You cannot append to the layer in the portal. However, since the data resides in the ArcGIS Server site's registered data store, append to the source data. |
Append to source data using ArcGIS GeoEvent Server. |
No |
Calculate field contents on the Data tab |
Yes |
No |
No |
No |
No |
Add or delete fields on the Data tab |
Yes |
You can add fields but not delete fields. |
No |
No |
No |
Yes |
No |
No; you can view existing lists and ranges but not add or delete them on the Data tab. |
No |
No |
Yes |
No |
No |
No |
No |
Enable or disable unique constraint on columns |
Yes |
No |
No |
No |
No |
Edit nonspatial field values on the Data tab |
Yes |
Yes |
Yes |
Yes |
No |
Alter field properties including display name (title), description, field value type, and whether edits are allowed for a field |
Yes |
Yes |
No |
Can edit display name and description but not other properties. |
Can edit display name, description, and field value type but cannot change edit setting for a field. |
Apply filters on the Visualization tab |
Yes |
Yes |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
Editing is automatically enabled and cannot be modified in the portal. |
No |
Enable sync for offline use and collaboration |
Yes |
No |
Yes |
No |
No* *Sketch layers and map notes layers saved as part of a web map are automatically enabled for offline use. Other feature collection layers or layer items do not support offline use. |
Yes |
No |
You cannot enable editor tracking in the portal. However, you can enable editor tracking on the source data from ArcGIS Pro. |
No |
No |
Control whether editable layers can be shared with everyone (public) |
Yes |
Yes |
No |
Yes |
No |
Update details, data, and visualization configuration for individual sublayers |
Yes |
Yes |
Yes |
Yes |
No |
