Use layers
How and where you use a web layer depends on the type of layer and what you need to do with it. The following are examples:
Use layers in maps and scenes to visually convey spatial information.
You can use layers, or the maps and scenes that contain the layers, in apps.
Use feature layers and imagery layers in analysis tools to discover patterns and extract information from the data.
Editable feature and table layers can be added to Map Viewer or apps to allow you to update feature and attribute data. In some apps, editable feature and table layers are added through web maps.
For hosted feature layers configured to allow it, you can obtain a copy of the underlying data by exporting the data from the hosted feature layer to a file.
Tip:
To determine whether a layer meets your needs, review the information on the layer's item page. Details such as the layer's description, metadata, and extent can help you decide whether the layer is suitable. For hosted feature layers, additional information about the individual fields in the layer is also available.
You build a map or scene by adding data layers to them and configuring how the layers look and behave in the map or scene. You can add layers you published, layers shared to you by others, and layers from other providers—such as ArcGIS Living Atlas—to the maps and scenes. You can use the options on the Overview tab in a layer's item page to open it in Map Viewer or Scene Viewer or you can start in one of those apps and add layers there. See Get started creating maps and Get started with scenes for overviews of the process to create the maps and scenes you and others can use to interact with your layers.
Feature layers can be used in analysis tools—in Map Viewer and ArcGIS Pro—and custom apps to answer spatial questions, discover patterns, and identify trends.
Use layers in apps
Apps are similar to tools in that many provide focused functionality that allows you to interact with the layers in your portal.
You must choose the app that meets the needs of the app users. Sometimes, you'll add a layer directly to an app, such as ArcGIS Pro, to use the layer as a basemap, provide reference information in a map, or edit or analyze features. In many other cases, you'll create and configure a map or scene containing the layers users need and add that map or scene to an app that provides specific functionality. You can create apps for that purpose, or use out-of-the-box apps such as ArcGIS Dashboards or ArcGIS GeoPlanner.
Edit features and tables
Feature and table layers that are configured to allow editing can be added to Map Viewer, where you can edit features or edit attribute in tables.
These editable layers can be edited in ArcGIS Pro. Editable feature and table layers can also be added to maps that you subsequently include in apps.
The owner of the feature layer or an administrator can also configure maps containing editable feature layers for offline use. The feature layers and the maps must be enabled for offline use. You could then load the map containing the editable, offline-enabled layers into an app, such as ArcGIS Field Maps, and collect and edit data while disconnected from the internet.
The layer owner, organization administrators, and members of shared update groups with which the layer is shared can edit a hosted feature layer, hosted spatiotemporal feature layer, or table layer's contents even when editing is not enabled on the layer. The only exception to this is if editing is disabled for specific fields in the layer; no one can edit those.
Export data from hosted feature layers or hosted tables
You can export data from a hosted feature layer or hosted table if one of the following is true:
You own the item.
You are an organization administrator.
You aren't the item owner or the organization administrator, but the hosted feature layer or table is configured to allow others to export the data.
When you export from a hosted table, a hosted feature layer, or one of its sublayers, ArcGIS Enterprise creates one of the following items in My content based on the format you choose when exporting:
CSV files—When you export from a point feature layer, latitude and longitude values for the points are exported to the
.csvfile. When you export a line or polygon feature layer, only nonspatial attributes are exported.Microsoft Excel files—When you export from a point feature layer, latitude and longitude values for the points are exported to the Excel file. When you export a line or polygon feature layer, only nonspatial attributes are exported.
Shapefiles
File geodatabases
GeoJSON files
Feature collections
KML files
GeoPackage files
If the hosted feature layer or table contains a field data type that is not supported by the export format, the export operation may fail.
After the item is created, you can download the file.
If the tables or layers in the source layer contain metadata, the metadata is included if you export to a shapefile or file geodatabase.
When you export from a hosted feature layer view, only the data included in the view definition is included in the exported file.
You cannot export data from a hosted feature layer that was created by ArcGIS Workflow Manager.
To export data from a hosted feature layer, hosted feature layer view, or hosted table, complete the following steps:
Sign in and open the item page for the feature layer or table to export.
Click the Export data button on the Overview tab and choose the format to export.
Tip:
You may need to click the Show more button
to see all options.If the layer you export contains attachments and you want to export the attachments, export to a file geodatabase. When you export to any of the other formats listed below, attachments are not included.
Export to Shapefile—Creates a compressed file (
.zipfile) containing a shapefile for each layer and its associated metadata (if present) that you export. You can download the file and save it to your computer. This option is not supported with hosted tables.Export to CSV file—Creates a comma-separated values file when you export from a layer. You can open the file or save it to your computer. If you export all layers to a
.csvfile, a CSV collection is created, which is a.zipfile containing one.csvfile per layer. You can download the.zipfile and save it to your computer.Export to KML—If you export a single layer, this option creates a KML service you can open in Map Viewer. When you export all layers to KML, a KML collection is created. This collection is a
.zipfile containing one KML file per layer that you can download. This option is not supported with hosted tables.Export to Excel—Creates a Microsoft Excel spreadsheet. You can open the file or save it to your computer. If you export all layers to Excel, each layer will be a separate sheet in the spreadsheet.
Export to FGDB—Creates a
.zipfile containing a file geodatabase. The file geodatabase contains a feature class and its associated metadata and attachments (if present). If the hosted feature layer has attribute indexes, the indexes are also created on the feature classes in the file geodatabase. You can download the.zipfile and save it to your computer.Note:
The
.zipfile uses the name you specify for the hosted feature layer's title, but the geodatabase name is randomly generated. Each feature class has the same name as the exported sublayers.Export to GeoJSON—Creates a GeoJSON file containing definitions for all layers you export. If you export from an individual layer, only that layer's definition will be present in the GeoJSON file. You can download the file and save it to your computer.
Export to Feature Collection—Creates a feature collection item you can open in ArcGIS Pro.
Choose Generalize features for web display to optimize the layer for web apps. You can only generalize features from layers published in the WGS 1984 Web Mercator (Auxiliary Sphere) coordinate system.
Exported feature collections that are generalized for web display do not work in desktop and mobile apps.
Alternatively, choose Keep original features if you need to maintain all the precision in the data or if you intend to use the feature collection in desktop or mobile apps.
Export to GeoPackage—Creates an Open Geospatial Consortium (OGC) GeoPackage file containing a spatial table for each layer. If you export from the hosted feature layer, the GeoPackage contains one spatial table for each feature layer in the hosted feature layer. If you export from a sublayer, only one spatial table is present in the GeoPackage. You can download the file and save it to your computer.
Provide a title for the exported file.
Choose or create the folder where the file will be stored.
Optionally, if categories are configured for your organization, assign them to the exported file.
Optionally, provide tags and a summary description for the exported file.
If you're exporting to a .csv or Excel file, choose the name to use as the header for the fields in the exported file.
Display name—The display name is the user-friendly name set for the field. This name can contain spaces and other characters that are not supported for field names.
When exporting to an Excel file, all spaces and special characters in the display name are replaced with underscores.
Field name—The field name is the text stored with the underlying feature service. This name is set when the hosted feature layer is published. It cannot contain spaces or nonalphanumeric characters.
Click Export.
An item in the format you chose is created in My content, and its item page opens.
For all formats except a feature collection, click Download on the Overview tab of the new item's page to save a local copy of the file.
Tip:
If you have privileges to perform spatial analysis, you can use the Extract Data tool in Map Viewer to export data from a hosted feature layer or hosted feature layer view that has export enabled.
