Deploy ArcGIS Data Store on Amazon Web Services (AWS)
ArcGIS Data Store is a required component of a base ArcGIS Enterprise deployment.
There are several ArcGIS Data Store types. See Functionality and apps that require system storage to determine what types of data store you need to include in your ArcGIS Enterprise deployment.
All data store types are registered with the hosting server.
When deploying on Amazon Web Services (AWS), register a cloud object store with the hosting server rather than configure an ArcGIS Data Store object store.
The following steps summarize how to configure ArcGIS Data Store on AWS. For these instructions, it is assumed that the ArcGIS GIS Server site on AWS that you will use as the hosting server for ArcGIS Enterprise on AWS already exists.
Tip:
Alternatively, you can use ArcGIS Enterprise Cloud Builder for Amazon Web Services to configure an ArcGIS Enterprise deployment on AWS that includes ArcGIS Data Store.
To add ArcGIS Data Store to an ArcGIS Enterprise deployment on AWS without using ArcGIS Enterprise tools for ArcGIS Enterprise, complete the following steps:
  1. Download the ArcGIS Data Store software from My Esri.
  2. Use an Amazon Machine Image (AMI) with a supported operating system to create Amazon Elastic Compute Cloud (EC2) instances.
    The operating system of the EC2 instances you use for ArcGIS Data Store should match the operating system of the other components in the ArcGIS Enterprise deployment to which you will add the data stores.
    It is recommended that each ArcGIS Data Store type run on its own EC2 instance. If you require a highly available or scalable data store, each data store will contain more than one EC2 instance.
  3. Install ArcGIS Data Store on the EC2 instance (or instances), but do not proceed with data store configuration yet.
    See Install ArcGIS Data Store for instructions. Use the operating system toggle to access the instructions appropriate to the operating system on the EC2 instance.
  4. Open the hostidentifier.properties file on the instance (or instances) where you installed ArcGIS Data Store, and remove the comment marks from the preferredidentifier=ip property.
    The file is in the <ArcGIS Data Store installation directory>\framework\etc directory.
  5. Start ArcGIS Data Store.
    • On Microsoft Windows instances, start the ArcGIS Data Store service from the Windows Services panel.
    • On Linux instances, sign in as the arcgis user and run startdatastore.sh, which is in the /arcgis/datastore directory.
  6. Create a relational store, configuring it with the GIS Server site on AWS that you'll use as the hosting server.
  7. If members of the organization will use functionality that requires other types of data stores (such as a spatiotemporal big data store or graph store), repeat steps 2 through 5 for each data store type to configure them on EC2 instances separate from all other data stores and ArcGIS Enterprise components.
    Configure each data store with the same GIS Server site as you configured for the relational store.
