Configure a CA-signed certificate for ArcGIS Server when accessed through ArcGIS Web Adaptor
When ArcGIS Web Adaptor has been configured to forward requests to your ArcGIS Server site, you need to enable HTTPS on the web server hosting ArcGIS Web Adaptor. To get started, follow the steps in the sections below.
Create a new self-signed certificate
Sign in to the ArcGIS Server Administrator Directory at
https://gisserver.example.com:6443/arcgis/admin.Browse to machines > [machine name] > sslcertificates.
Click generate.
Provide values for the parameters on this page:
Option
Alias
A unique name that easily identifies the certificate.
Key Algorithm
Use RSA (the default) or DSA.
Key Size
Specifies the size in bits to use when generating the cryptographic keys used to create the certificate. The larger the key size, the harder it is to break the encryption; however, the time to decrypt encrypted data increases with key size. For DSA, the key size can be between 512 and 1,024. For RSA, the recommended key size is 2,048 or greater.
Signature Algorithm
Use the default (SHA1withRSA). If your organization has specific security restrictions, one of the following algorithms can be used for DSA: SHA256withRSA, SHA384withRSA, SHA512withRSA, SHA1withDSA.
Common Name
Use the domain name of your server name as the common name.
If your server will be accessed on the Internet through the URL
https://www.gisserver.com:6443/arcgis/, use www.gisserver.com as the common name.If your server will only be accessible on your local area network (LAN) through the URL
https://gisserver.example.com:6443/arcgis, use gisserver.example.com as the common name.Organizational Unit
The name of your organizational unit, for example, GIS Department.
Organization
The name of your organization, for example, Esri.
City or Locality
The name of the city or locality, for example, Redlands.
State or Province
The full name of your state or province, for example, California.
Country Code
The abbreviated code for your country, for example, US.
Validity
The total time in days during which this certificate will be valid, for example, 365.
Subject Alternative Name
The subject alternative name (SAN) is an optional parameter that defines alternatives to the common name (CN) specified in the certificate. There cannot be any spaces in the SAN parameter value.
If this parameter is left empty, the fully qualified domain name of the local machine is used as the default value. The SAN field supports multiple values; however, it must include the fully qualified domain name of the website. For example, the URLs
https://www.esri.com,https://esri, andhttps://10.60.1.16can be used to access the same site if the certificate is created using the following SAN parameter value:DNS:www.esri.com,DNS:esri,IP:10.60.1.16Click Generate to generate the certificate.
Request a CA to sign your certificate
If ArcGIS Web Adaptor will be the only gateway to your site and your organization's IT security policy allows the use of self-signed certificates, you can skip this section. However, if users will occasionally bypass ArcGIS Web Adaptor and access ArcGIS Server directly or your IT policies disallow the use of self-signed certificates, it is recommended to request a CA to sign your certificate by following the steps below.
Open the self-signed certificate you created in the previous section and click generateCSR. Copy the contents into a file, usually with a
.csrextension.Submit the CSR to a CA of your choice. You can obtain a Distinguished Encoding Rules (DER) or Base64 encoded certificate. If the CA requests the type of web server the certificate is for, specify Other\Unknown or Java Application Server. After verifying your identity, the CA will send you a
.crtor.cerfile.Save the signed certificate you received from the CA to a location on your computer. In addition to the signed certificate, the CA will also issue a root certificate. Save the CA root certificate to your computer.
Sign in to the ArcGIS Server Administrator Directory: https://gisserver.example.com:6443/arcgis/admin.
Click machines > [machine name] > sslcertificates > importRootOrIntermediate to import the root certificate provided by the CA. If the CA issued any additional intermediate certificates, import those as well.
Click the name of the self-signed certificate that you submitted to the CA.
Click importSignedCertificate and browse to the location where you saved the signed certificate you received from the CA.
Click Submit. This replaces the self-signed certificate you created in the previous section with the CA-signed certificate.
Configure ArcGIS Server to use the certificate
To specify the certificate that ArcGIS Server should use, complete the following steps:
https://gisserver.example.com:6443/arcgis/admin.Browse to machines > [machine name].
Click edit.
Type the name of the certificate that you want to use in the Web server SSL Certificate field.
Click Save Edits to apply your change. This automatically restarts your ArcGIS Server site.
After your site has restarted, verify that you can access the URL
https://gisserver.example.com:6443/arcgis/admin. If you do not get a response from this URL, ArcGIS Server was unable to use the specified SSL certificate. Check your SSL certificate and configure ArcGIS Server to use a new or different certificate.On the current page, view the property Web server SSL Certificate to verify that the desired certificate will be used for HTTPS.
Configure each machine in your deployment
If you have a multiple-machine deployment of ArcGIS Server, you must configure each machine in your deployment to use the certificate. Repeat the steps in the previous section to configure the certificate with each of your ArcGIS Server machines.
Configure HTTPS on ArcGIS Web Adaptor
Enable HTTPS on the web server that is hosting ArcGIS Web Adaptor. For full instructions, consult the product documentation specific to your web server.
Enable HTTPS on the web server that is hosting ArcGIS Web Adaptor. For full instructions, consult the product documentation specific to your web server. To learn more, see Enable HTTPS on your web server.
Access your site
You can securely access ArcGIS Server directly though HTTPS using port 6443 or the Web Adaptor URL. If you rename your ArcGIS Server site, you can continue to access ArcGIS Server using HTTPS; however, you must generate a new certificate and configure ArcGIS Server to use it. The URLs are formatted as follows:
ArcGIS Server Manager |
Access Manager through the server: Access Manager through ArcGIS Web Adaptor: |
ArcGIS Server Services Directory |
Access Services Directory through the server: Access Services Directory through ArcGIS Web Adaptor: |
