System requirements for Indoors Space Planner
Available with the ArcGIS Indoors Spaces extension.
To use Indoors Space Planner, an ArcGIS Enterprise base deployment licensed for the ArcGIS Indoors Maps and ArcGIS Indoors Spaces extensions are required. Refer to the ArcGIS Enterprise help for system requirements and instructions on how to install and configure an ArcGIS Enterprise deployment.
To use Indoors Space Planner, an ArcGIS Online organization licensed for the ArcGIS Indoors Maps and ArcGIS Indoors Spaces extensions are required. Refer to the help to set up an ArcGIS Online organization for use with Indoors.
Required ArcGIS software
The following ArcGIS software is required for Space Planner:
- ArcGIS Pro 3.0 or later
ArcGIS Server Standard
Portal for ArcGIS 11.0 or later licensed for ArcGIS Indoors Maps and ArcGIS Indoors Spaces
- An ArcGIS Online organization licensed for ArcGIS Indoors Maps and ArcGIS Indoors Spaces
Required user types and roles
Certain permissions are required to interact with the Space Planner app. These requirements are summarized in the table below.
Action |
Required user type or role |
Access the Space Planner app |
Contributor user type or higher |
Create the Space Planner app |
Publisher default role or higher Publisher default role or higher |
Create a plan |
Open, edit, and merge changes in plans |
Data Editor default role or higher |
Read more about configuring roles and permissions for Space Planner
Branch versioning in ArcGIS Enterprise
Branch versioning is required to change a plan's assignments in Space Planner. Branch versioning is supported by ArcGIS Enterprise 10.6.1 or later geodatabases that are created in ArcGIS Pro 3.0 or later. The database platform you use must also support branch versioning.
Learn more about branch versioning data for use with Space Planner
The following database platforms are supported:
Database |
Minimum release that supports branch versioning |
10.5 Fix Pack (FP) 5 |
13.0.1601.5 (2016) |
12.1.0.2 Note:Branch versioning is not supported in user-schema geodatabases. |
9.5.3 |
2.0 Support Package Stack (SPS) 02 |
Avoid compatibility-related issues and benefit from the latest bug fixes and performance improvements by updating the geodatabase to a version that is compatible with the ArcGIS Pro version you are using. The ArcGIS Pro and geodatabase versions must match when using branch versioning.
You can use the Upgrade Geodatabase tool to upgrade your geodatabase. Learn more about upgrading a geodatabase in the following database platforms:
Supported browsers and devices
This app supports all of the browsers that ArcGIS Enterprise supports.
This app supports all of the browsers that ArcGIS organizations in ArcGIS Online support.
Space Planner is designed to be accessed from a web browser running on a desktop or laptop. This app can run on browsers on portable devices such as touchscreen tablets, but some capabilities such as drag and drop may be unavailable.
Supported languages
This app supports all of the languages that ArcGIS Enterprise supports.
This app supports all of the languages that ArcGIS Online supports.
The language used by the app is determined by your browser's language setting.
