Install the ArcGIS Maritime server extension silently
Available with Advanced license.
Available with ArcGIS Maritime license.
The ArcGIS Maritime server extension can be installed without a user interface by running the setup.exe command from the Command Prompt window.
Installation prerequisites include the following:
  • Verify that the system meets the system requirements.
  • Obtain an authorization file for the machine on which you will be installing the Maritime server extension.
  • Sign in as a user with administrative privileges.
  • Install ArcGIS Server.
In certain scenarios, the ArcGIS Server account can be set to the LocalSystem account before installing the Maritime server extension. In these scenarios, it is recommended that you change the ArcGIS Server account by running the Configure ArcGIS Server Account utility.
Learn more about changing the ArcGIS Server account.
To install the Maritime server extension silently complete the following steps :
  1. Open a Command Prompt window.
  2. Browse to the directory where the setup.exe file is located.
  3. Use the following command to install the software silently:
    <Path to ArcGIS Maritime server extension>\setup.exe /qb
To install the Maritime server extension in an ArcGIS Server multimachine deployment, run the above command on each machine in the site.
Use ArcGIS Experience Builder widgets to deploy custom web apps and try the latest features available with Maritime widgets.
The silent install process is not available for Linux implementations of the ArcGIS Maritime server extension.
