Install the ArcGIS Maritime server extension
Available with Advanced license.
Available with ArcGIS Maritime license.
The following steps guide you through the ArcGIS Maritime server extension installation process.
Ensure that the following prerequisites are completed before installation:
Verify that the system meets the system requirements.
Install ArcGIS Server.
Download the ArcGIS Maritime server software package from My Esri.
Obtain an authorization file for the machine on which you are installing the Maritime server extension.
Once the prerequisites are completed, complete the following steps to install the ArcGIS Maritime server extension:
The Maritime server installation must be performed from the same user account used to install ArcGIS GIS Server.
Sign in to the machine as a user with administrative privileges.
Start the ArcGIS Maritime server extension setup program.
Browse to the location that contains the
MaritimeServerLinux-<version>.<build number>.tar.gzsetup package and run the following command to uncompress it:$ tar -zxvf MaritimeServerLinux-<version>.<build number>.tar.gzClick Next on the Welcome to the ArcGIS Maritime server extension Setup Program pane of the installation wizard.
The License Agreement dialog box appears.
Run
Setup.shto start the installation:$ ./ArcGISMaritimeServer/Setup.shReview the license agreement and accept it or close the dialog box if you do not agree with the terms.
Click Next.
The Custom Setup dialog box appears.
PDF Merge Support is required for Custom Chart Builder deployments. Without this feature, PDF documents cannot be exported from the CCB app.
Browse to
<ArcGIS Server installation directory>/MaritimeServerto verify the contents of the uncompressed setup package.The package should contain the following:
Bin
MaritimeServer.soemcstpk.exeweb.config.xml
maritimechartservice folder with four subfolders:
controlfiles
datasets
logs
sencs
Accept the default directory (
C:\ProgramFiles\ArcGIS\MaritimeServer\Server<version>) or choose a different location, and click Next.The Ready to install the Program dialog box appears.
Click Install to begin the installation.
Once the installation is complete, the InstallShield Wizard Completed dialog box appears.
Click Finish.
Maritime server is now installed on the local machine. To install Maritime server in a multimachine deployment, repeat the installation steps on each machine.
Use ArcGIS Experience Builder widgets to deploy custom web apps and try the latest features available with Maritime widgets.
